Old Jul 20th, 2004, 11:46 PM   #1 (permalink)
Wharf Rat
04 sentra tach installation help, please
Hi, I'm trying to help my son install an aftermarket tach on a new sentra. It has the 1.8L engine, and I can't even find the coil. (Does it have one?)
I'd appreciate some help on which wires to connect up. It is a four wire tach, two of them are positive, one for "key on" and one for "always hot". Another one goes to negative coil and one to ground. The coil wire may also go to a "tach" connection if there is no coil on the car.
Anyway, thanks in advance, I appreciate your help. Peter
Wharf Rat is offline   Reply With Quote
Old Jul 21st, 2004, 12:12 AM   #2 (permalink)
chimmike
Powered By hopes & dreams
chimmike's Avatar
you look under the hood? heh, the 4 things on the valve cover are the coil packs. this car is direct ignition, coil-on-plug. This requires the use of an autometer tach adapter. it can be had from summitracing.com
My Website, check it out!
Do You Have a Nissan More than 10 years old ? You are challenging Nissan...read Pablo14 General Discussion 34 Oct 18th, 2007 01:53 AM
Engine Knock on Mexican built GA16DE Sentras Pablo14 GA16DE 1.6L Engine 44 Jul 5th, 2006 11:16 PM
A dealer and an independent tech can't eliminate erratic idle; HELP, if you can.... Pablo14 GA16DE 1.6L Engine 88 Nov 29th, 2004 01:30 PM
Looking for a gauge cluster with a tach to put into my 94 non tach cluster 94Sentra Canada & International 0 Nov 10th, 2003 03:09 PM
GB: Tein Type-SS Coil-over Sentra TurboEvo Group Buys 168 Jul 7th, 2003 09:00 PM
