Old Jun 10th, 2004, 06:27 PM   #1 (permalink)
Philabong
Angry Fuel Filter
My QG18 GXE is currently in a service bay @ Tustin Nissan.
I took it it for service thinking there was a bigger problem than the fuel filter.
They want to chage $280 bucks to replace it.
How much was your replacement fuel filter/pump.
Symptoms were as follows:
Hessitation
Odd 'blow' noise @ 4k rpm
power loss.
I've called 4 other nissan dealers in the area with all different results...
mark - buena park nissan - $54
Tom - garden grove nissan - $99
lance- power nissan irvine - NO FUEL FILTER
frank - CONNELL NISSAN - Fuel Filter never needs replacing
help me, im a :dumbass:
Philabong is offline   Reply With Quote
Old Jun 10th, 2004, 07:23 PM   #2 (permalink)
chimmike
Powered By hopes & dreams
chimmike's Avatar
the last guy is right. The fuel filter never needs replacing. It's either the pump, or something else, but I can't diagnose if I don't know the symptoms.
do you have any modifications?
My Website, check it out!
Old Jun 10th, 2004, 07:40 PM   #3 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
that's right by my house! (tustin Nissan I mean)
what other symptoms are there? please be more detailed about it...
05 Frontier SE CC 4x4 (6spd)
Old Jun 10th, 2004, 07:46 PM   #4 (permalink)
Philabong
On a cold start, the engine spats and sputters about for a few minutes whilst lightly pumping the gas. after a bit of that, the engine revs normally out of gear.
around 3800-4400 rpm, very audible noise. sounds like hissing.
noticable power reduction.
piss poor gas milage.... ~250mpt, normally ~325mpt
my car is a bone stock QG18DE
*am i correct in assuming there is some sort of VVT for this engine type, because that's what it feels like. The noise starts when the engine is topping out of the first timing set and stops once it changes to the newer timing. The dealer said this noise was cause by the engine straining because my mix is so lean. I deffinately do not disagree that the engine is having trouble getting fuel.
Old Jun 10th, 2004, 07:58 PM   #5 (permalink)
chimmike
chimmike's Avatar
sounds to me like an exhaust leak near the manifold/block gaskets or manifold/secondary...or perhaps at the cat.
perhaps fuel pump, but definitely not fuel filter.
Old Jun 11th, 2004, 01:01 AM   #6 (permalink)
Philabong
Question
dealer called 15 mins before they closed.
fuel filter = replaced?
and now I need a MAFS.... for $500.
Old Jun 11th, 2004, 12:42 PM   #7 (permalink)
chimmike
chimmike's Avatar
yup, knew it wasn't the fuel filter, that's total BS
tell me exactly what the car does.......................
Old Jun 11th, 2004, 12:51 PM   #8 (permalink)
Philabong
AIM = EdFromMesa
YIM = Phillabonger
i don't think i can clearly relay to you what you want to know in this fashion.
Old Jun 15th, 2004, 12:24 PM   #9 (permalink)
Philabong
Quick update.
Got my car back from the dealer noonish on Friday. Freshly washed and the belts lubed due to some skwakage. Laid down $280 cash and Dan told me that I needed a new MAF, which he'd already told me. Asked the parts guy how much a MAF runs, $488 and change. Yoiks. Get in the car and go.... almost. The hessitation problem I had in the AM before warm up now happens all the time, through all gears and is much worse than before. The more gas the engine got, the less it would go. I was livid. I took it to my buddies around the corner and left it there. Tried to do some searching for a used or cheaper MAF. Didn't find anything till yesterday at about 10 AM. Mike's Import Parts in WIlmington had one. Called em up and "Mike" (mexican named Julio) quoted me $125. SCORE! Took off from work at lunch and told them I'd be a while (Irvine to WIlmington, which is located on the north side of the Long Beach Harbor) and made the drive to Mike's. Found the location easily, walked in and they had the part ready, did the exchange and Mike was going to tell me how they don't give refunds. He also asked me if this would fix my problem. I told him I did not know being that it was a dealer recomended repair. He said Fucking dealers, if it doesn't fix it you can bring this back for any other parts you need. Good guys at Mike's. Drove back to work and finished out my day. The 2.5 hour break was nice. After work I went to my car and swapped the MAFs. Easy peasy, took maybe 7 minutes. A quick trip to Autozone for a new air filter and it was time for the test. PERFECT. Car runs great. Much better than I did before I took it in. So the dealer railed me nicely for that Fuel Filter swap, but I made up the difference with a little leg work and paid 1/4 price for my MAF.
w00t. thanks for your help guys.
Old Jun 15th, 2004, 01:01 PM   #10 (permalink)
chimmike
chimmike's Avatar
congrats. you should go back to the dealer and ask them where in maintenance schedules it ever calls for a fuel filter change
Old Jun 15th, 2004, 01:08 PM   #11 (permalink)
2000sentra
Great info. I just joined this forum because of this exact problem. My QG18 hesitates and even stalls sometimes in the mornings. It also has a fraction of the power it used to. It makes noise at around 3000+ RPM. The dealer said I needed a new MAF too ($500 bucks!). I'm going to look around for a better price also. Was the one you got from "Mike's" used?
2000sentra is offline   Reply With Quote
Old Jun 15th, 2004, 01:29 PM   #12 (permalink)
chimmike
chimmike's Avatar
www.car-part.com for good prices on used parts.
Old Jun 15th, 2004, 01:47 PM   #13 (permalink)
Lucino200sx
Nissan Fanatic
Lucino200sx's Avatar
Send a message via AIM to Lucino200sx
Originally Posted by Philabong
Quick update.
Good job! Glad to hear you didn't get totall y raped by the stealership.
1995 200SX SE
2004 CRV LX
2004 Corolla LE
Lucino200sx is offline   Reply With Quote
Old Jun 15th, 2004, 03:51 PM   #14 (permalink)
Philabong
I'm 100% sure it was.
came out of box with the part # written with chalk on it.
it was deffinately a wrecking yard. Howver it was clean ass clean could be. no scuffs or any marks. I was confident it would work fine.
Old Jun 21st, 2004, 02:28 PM   #15 (permalink)
richiebby
Crazy man!
The two guys above are crazy,
1) You Do have a fuel filter.
2) I bought my car used (1999 SSS bluebird from Japan qg18DE powered) so I have a japanese manual,(which I threw away). Anyway, you may want to check the fuel filter for sediment every time you clean your injectors (I do this every 6 months) and throttle plate (once a year). If you have crap in your tank, though the filter is quite robust, it can clog. Nothing lasts forever, especially filters!!. I paid 30 bucks for my replacement filter @100,000 KM, though it was a japanese, not american make. Don't know if there is any difference.
richiebby is offline   Reply With Quote
replacing fuel filter Ninety-Nine SE-L GA16DE 1.6L Engine 21 May 17th, 2004 06:06 PM
Fuel Filter on 96 Altima altima96gxe U13 1993-1997 Altima 3 May 10th, 2004 11:05 PM
1998 Frontier fuel filter location 2WD Cusser Truck & SUV 2 Apr 18th, 2004 12:48 PM
fuel filter maybe? help! 96sentra GA16DE 1.6L Engine 6 Dec 31st, 2003 12:21 AM
fuel filter problem rshattuck U13 1993-1997 Altima 3 Apr 15th, 2003 09:51 PM
