Old Oct 19th, 2002, 10:04 PM   #31 (permalink)
PatScottAKA99XE
ex-Super *********
PatScottAKA99XE's Avatar
Send a message via AIM to PatScottAKA99XE Send a message via Yahoo to PatScottAKA99XE
Confusing, isn't it?
Patrick Scott
Yeah, thats a roll cage in there.
I shall call him...Mini-Me
PatScottAKA99XE is offline   Reply With Quote
Old Oct 19th, 2002, 11:42 PM   #32 (permalink)
chimmike
Powered By hopes & dreams
chimmike's Avatar
there are many QG owners with headers that have not had to relocate their sensors......................
My Website, check it out!
Old Oct 20th, 2002, 10:29 AM   #33 (permalink)
PatScottAKA99XE
ex-Super *********
Just wondering, what did they do with them?
Patrick Scott
Old Oct 20th, 2002, 11:04 AM   #34 (permalink)
chimmike
chimmike's Avatar
put them in the secondary where the bungs are that HS welds in.
I am not even running the bottom 2 O2 sensors, lol. I'm having enough trouble getting them out of the stock manifold =)
Old Oct 20th, 2002, 03:18 PM   #35 (permalink)
PatScottAKA99XE
ex-Super *********
You have 4 sensors and I thought the HS only had 2 fittings, hows that work?
Patrick Scott
Old Oct 20th, 2002, 03:20 PM   #36 (permalink)
e2001gxe
Send a message via AIM to e2001gxe
Two are on the header itself and the other two are on the downpipe.
2001 GXE CV2-H
e2001gxe is offline   Reply With Quote
Old Oct 20th, 2002, 03:27 PM   #37 (permalink)
PatScottAKA99XE
ex-Super *********
Ok, thanks. Just to let you guys know.. If you put the 2 rear O2 sensors in the down pipe, its not gonna do any good. They need to be behind a cat or the ECU will think that something is wrong(Well, there is!)
The ECU is looking for this:
Front O2 sensors - raw ehxaust. The ECU can determine what adjustments need to be made to the a/f ratio by reading the raw exh.
Rear O2 sensors - cat cleaned exhaust. The ECU uses these O2s to tell if the cat is working right.
So you see if you put the rear O2 sensors in the down pipe the ECU will get a raw exhaust signal from them. This makes the ECU think that the cat is not working, and will set off the check engine light.
Patrick Scott
Old Oct 20th, 2002, 05:12 PM   #38 (permalink)
e2001gxe
What does the ECU do in response? Does it make the A/F mixture rich or lean?
-Eric
2001 GXE CV2-H
Old Oct 20th, 2002, 05:22 PM   #39 (permalink)
PatScottAKA99XE
ex-Super *********
-Eric
Nothing, it just turns on the check engine light. Rear O2 sensors have nothing to do with A/F ratios, they are only there to monitor cat efficency(sp).
Patrick Scott
Old Oct 20th, 2002, 05:31 PM   #40 (permalink)
e2001gxe
Then I'm getting crappy gas milage for other reasons. =D Thanks for the reply.
2001 GXE CV2-H
Old Oct 20th, 2002, 07:19 PM   #41 (permalink)
chimmike
chimmike's Avatar
I noticed that too. me=heavy foot
lol
Old Oct 20th, 2002, 07:31 PM   #42 (permalink)
e2001gxe
Mike,
What's the range ur getting on 1 tank? Before mods and wheels I was averaging 360. Now (after header and 16's) I only get about 300-barely. That's like 33 before and 27-28 now. Quite a difference. Although my heavy foot is not too bad.
2001 GXE CV2-H
Old Oct 25th, 2002, 09:24 PM   #43 (permalink)
khemicol
Send a message via AIM to khemicol
has anyone gotten really bad vibrations after the header install and the car driving like a pig???
My O2s are still on the secondary BTW.
Khem
khemicol is offline   Reply With Quote
Old Oct 26th, 2002, 01:23 AM   #44 (permalink)
pdid11
Posts: n/a
I had mean vibrations when my secondary bolts came loose, didnt drive like a pig but sounded terrible. I heard the heat sheild makes some harsh noise.
Old Oct 26th, 2002, 01:36 AM   #45 (permalink)
PatScottAKA99XE
ex-Super *********
Wish I could have seen this before:
http://lion.esosoft.net/hotshot.com/headers/CEL.htm
In your guys case its 4 O2s intead of 2
Patrick Scott
Hot Shot headers are out for the 3.5 3.5SE Auto L31 2002 - 2006 16 Sep 13th, 2003 06:23 PM
Hot Shot CAI MorrisMcD QR25 2.5L Engine 5 Jun 24th, 2003 03:36 PM
Hot Shot Headers Zimmy57 GA16DE 1.6L Engine 5 Dec 4th, 2002 01:13 PM
Hot Shot header SRV1 GA16DE 1.6L Engine 5 Nov 10th, 2002 02:24 PM
New to the Forum, question on Hot Shot Performance. SpecVA QR25 2.5L Engine 15 Jul 2nd, 2002 05:03 PM
