you'll see the drain and fill pretty easily. Drain requires a 14mm hex...I suggest getting the one that fits in a socket wrench, that thing will be TIGHT. Fill requires a 10mm hex head. Drain is on the side facing the wheel. fill is on the front facing the bumper. (of the tranny of course)
whatever you do, DO NOT use anything rated GL5...it will eat away the synchros.
only real motored toys left:
'06 GSX-R 1000
'07 Mazdaspeed3- injen CAI.
