Old Feb 16th, 2004, 03:18 AM   #1 (permalink)
gr33nz0rs
Headlight Issues
Can anyone give me an insight to my problem. My left headlamp doesn't work and it makes my highbeam light come on all the time, even though my light is on low beam. We checked the fuse its ok. We also tried the goodlight on the left side and it did the same thing. I dunno whats else to try.
gr33nz0rs is offline   Reply With Quote
Old Feb 16th, 2004, 10:27 AM   #2 (permalink)
chimmike
Powered By hopes & dreams
chimmike's Avatar
first question: are you using aftermarket light bulbs?
If the answer is yes, are they higher wattage than stock?
if that answer is yes, you've begun to melt the harness. Take out those bulbs, look at the harness plug where to plug it into the bulb, it's probably got some "meltage" in there. Go back to stock wattage bulbs.
either way it's a good idea to check the harnesses, but I'm thinking that might be your problem.
My Website, check it out!
Old Feb 17th, 2004, 01:50 AM   #3 (permalink)
gr33nz0rs
yea thats it. thxdoode... i put the stock back
Old Feb 17th, 2004, 06:58 AM   #4 (permalink)
chimmike
chimmike's Avatar
same thing happened to me and many others
there are upgraded harnesses you can buy that won't do this, however they aren't cheap and I can't remember where to get them, lol
idle issues outsider A32 1995-1999 Chassis 7 Mar 23rd, 2004 12:05 AM
headlight alignment Q FadedKM83 B14 95-99 chassis 0 Jan 11th, 2004 03:43 PM
why only one headlight?? 96sentra B14 95-99 chassis 12 Nov 18th, 2003 06:22 PM
Headlight Issues Rama General Discussion 6 May 10th, 2003 01:34 PM
idle issues on my 84 Max!! Javelin General Maxima Discussion 2 Apr 29th, 2003 04:39 AM
