Old May 4th, 2002, 10:49 AM   #1 (permalink)
cla
Posts: n/a
Check engine soon
How can i read the error code on my 2001 sentra without any expensive tool? I know on any car we can read the code by watching the engine light flashing.
Also, how can I reset this "check engine" light when my problem is solved?
Thanks
Claude
Old May 5th, 2002, 06:05 AM   #2 (permalink)
KSipmann
Banned
KSipmann's Avatar
Well to actually read the code you'll need a Consult II. You could use a manual as well if you've got one that lists all the codes.
As for removing the CEL, it really depends on whats causing the CEL to come on. Usually you can just unplug the battery for a few hours and let the ECU reset itself. Just depends on why the CEL is on.
KSipmann is offline   Reply With Quote
not sure where this goes...check engine light? Tickwomp Off Topic 4 Jun 11th, 2003 04:41 AM
check engine light-engine knock sensor tripped diamond L30 1998-2001 Altima 8 May 27th, 2003 12:41 PM
having trouble with my engine check light palengkeboy S13 240SX 1989-1994 4 Feb 5th, 2003 04:39 PM
check engine light & emissions nismofreak GA16DE 1.6L Engine 5 Jan 22nd, 2003 12:15 AM
check engine light drpepper911 B14 95-99 chassis 14 Jun 19th, 2002 01:57 PM
