2002 Nissan Sentra - Timing Sprocket Removal - Nissan Forum
post #1 of 3 Old Oct 13th, 2012, 10:02 PM Thread Starter
I'm removing the head on a 1.8 and I can't get the variable timing sprocket off the cam shaft. I used a wrench to hold the cam stationary and with a breaker bar I could not get the bolt to break loose. I did not apply air to the one oil port toward the fire wall ...any suggestions would greatly be appreciated!!
Thanks,
Mike
slimeymike is offline
post #2 of 3 Old Oct 20th, 2012, 09:58 PM
Those have a lot of torque to them. I can't recall exactly what the spec was, but that it was the highest torque I had when I did mine.
I used a BIG crescent wrench to hold the cam, with a fairly large set of vice grips locked onto the end of the handle for extra length adding up to the length of a 1/2 inch drive flex bar. And the only socket wrench I had long enough for the sprocket bolt was the torque wrench with which I put it back on later.
Last edited by bobpeters61; Oct 20th, 2012 at 10:02 PM. Reason: Accidently posted before finished writing.
bobpeters61 is offline
post #3 of 3 Old Oct 21st, 2012, 09:47 AM Thread Starter
Thumbs up timing sprocket
thanks for the input. Sorry for the late reply PC has been down. I used a large breaker bar and a 21mm wrench with a pipe on the it my son held the wrench while I went for broke with the breaker bar and it worked! I had tried a impact wrench rated at 245ft/lbs and it would not budge. I'm amazed a 10mm bolt could handle that much torque. I got the head back from the machine shop with minor resurfacing and headbolts and gaskets form Rockauto. I will try to put it back together this weekend. thanks Mike
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > QG18 1.8L Engine
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
