Links
Go Back   NissanForums.com > Nissan Models > Sentra, Pulsar, NX, B14 200SX > QG18 1.8L Engine
Old Mar 18th, 2008, 08:51 PM   #1 (permalink)
walt911sc
Ignition Coil Problems
This is a 2001 Sentra with 180K miles, never serviced for ECM foam or Crank Position Sensor recall. Currently getting a code for engine misfire.
Spark plug number 1 shows no sign of fireing. Replaced igntion coil and car ran fine for about 1 hr before problem returned. The replacement igntion coil was overheating and was literally fried.
Took car to dealer for two recalls and a diagnostic check of the igntion coil. The dealer claims the ECM is bad and cannot diagnose the problem or complete the recall without replacing the ECM and coil.
Can a faulty ECM be responsible for the coil failures and how can I troubleshoot the situation to verify?
Thanks.
walt911sc is offline   Reply With Quote
Old May 8th, 2008, 08:47 AM   #2 (permalink)
ob_one
Did you find out what the problem was? I have a similar problem as well.
ob_one is offline   Reply With Quote
Old May 8th, 2008, 10:45 AM   #3 (permalink)
walt911sc
I had to replace the ECU unit and the ignition coil to fix this. Purchased a rebuilt ECU with 1 year warranty for about $425. Try just replacing the coil first.
