Old Mar 14th, 2008, 10:34 PM   #1 (permalink)
aorozco2
2005 transmission flush *need advice/info*
hi, i am in the process of doing a transmission flush on my car it has 85k mi. and i wanted to know when is it recommended to do it at, mileage wise? and also how to do it because i want to do a complete flush and i know if i just drain it i will only get a portion of th fluid so how do i go about doing a complete flush, as far as getting all of the fluid in te converter and trans. cooler.
so if any one has a link to a site with instructions, that would really help me out.
aorozco2 is offline   Reply With Quote
Old Mar 17th, 2008, 05:12 AM   #2 (permalink)
Jarek
g33k/gamer/QR nerd
Jarek's Avatar
Send a message via MSN to Jarek Send a message via Yahoo to Jarek
phatg20.net has the Factory service manual you can download tells you how to service your entire car and them some.
Not sure at what mileage interval the change is required I know its less than every 30k miles. It actually says in your user manual in the car. From what it says.... a flush is not required its a drain and fill operation.
Its not what you know, its who you know
05 Brilliant Aluminum Spec V - ES MMI's Recieved! pending install
04 Blackout Sentra 1.8s! = stock = Traded in 06/27/05!
http://myspace.com/rv_jd MYSPACE PROFILE PAGE
Jarek is offline   Reply With Quote
