Old Dec 3rd, 2007, 12:16 AM   #1 (permalink)
cutehumor
White smoke from under hood need help diagnosing
2003 Nissan sentra XE 1.8L 78k miles
my dad told me that he had white smoke coming from underneath the hood with a strong smell. no codes,no overheating. Headgasket was replaced 25k miles ago. I was wondering where should I look at to check for the source of the problem? He told me it was coming from the back of the engine. oil was changed four months ago and it is still full he says. any tips to look?
cutehumor is offline   Reply With Quote
Old Dec 3rd, 2007, 10:30 AM   #2 (permalink)
b15chik
Moderator
b15chik's Avatar
Send a message via AIM to b15chik Send a message via Yahoo to b15chik
well i would first say to make sure there are no leaks in your coolant hoses. what kind of bad smell? you can usually tell if the smell is oil or coolant. maybe they spilled some oil when you changed it last and it's just burning off? is this still going on? or was it a one time thing?
b15chik is offline   Reply With Quote
Old Dec 4th, 2007, 07:04 PM   #3 (permalink)
cutehumor
it's an exhaust type of smell coming from the back of the engine. it's white smoke. it's at start up and shut off. oil was changed four months ago. oil is still full on dipstick.
Old Dec 5th, 2007, 10:05 AM   #4 (permalink)
b15chik
Moderator
b15chik's Avatar
four months ago? someone needs to get on the ball
i'd probably just check it out back there when you're changing the oil. turn the car on and see where it's coming from. sounds like it might just be a small leak somewhere
Old May 16th, 2008, 03:18 PM   #5 (permalink)
justforinfo
I dont mean to thread jack but does anyone have a link to a DIY for a headgasket? I cant find anything anywhere.
justforinfo is offline   Reply With Quote
Old May 17th, 2008, 11:50 AM   #6 (permalink)
b15chik
Moderator
b15chik's Avatar
if you're not mechanically inclined, i probably wouldn't recommend doing it. you can get the fsm at PhatG20 - Home.
Old May 17th, 2008, 12:09 PM   #7 (permalink)
rogoman
Keeping the peace
rogoman's Avatar
Check the exhaust manifold nuts to make sure they are tight; just don't apply any gorilla action with the wrench or else you can break the stud off. You may have to end up replacing the exhaust manifold gasket if all the nuts are tight.
KA > SR anyday of the week.
white smoke from exhaust -loss of compression skyrider20 B14 95-99 chassis 2 Aug 18th, 2007 10:39 AM
White Smoke at Cold Start goldenes Naturally Aspirated 4 May 19th, 2007 08:51 PM
smoke coming from hood, jovanni U13 1993-1997 Altima 4 Jul 14th, 2005 02:30 AM
Very little white smoke... 200sx98fl B14 95-99 chassis 18 Apr 14th, 2005 04:00 PM
white tail pipe smoke at start up Slvr_01_Pathfinder Truck & SUV 5 Mar 29th, 2005 12:09 PM
