Old Oct 22nd, 2007, 11:10 AM   #1 (permalink)
alsc22ozz
Unhappy '04 1.8 not starting
So I am new and i am not happy with my Nissan, It is such a pain that i would love to trade it but i would loose to much money on it. Anyway I bought my Sentra used and since i bought i have had starting issues, i can go out in the AM and it starts fine but if I drive a ways and go out to start it after more then 15 min it just cranks for about 10-30 sec and then maybe it will start. and then has been 5-6 times then it ust does not start, so i disconnect the battery and pull the plugs and coil pack, wait about the hour and put it back together and it starts after some cranking and pumping of the fuel pedal. then the cycle contunies. When i put it on the computer it only says that there is a missfire in the #3 cylinder. So can anyone help me PLEASE?!?:
'04 Sentra 1.8
"Its all about the man standing next to you."
alsc22ozz is offline   Reply With Quote
Old Oct 22nd, 2007, 04:53 PM   #2 (permalink)
Z_Tuned_R34
Z_Tuned_R34's Avatar
Did you check the spark plugs and wires?
Z_Tuned_R34 is offline   Reply With Quote
Old Oct 22nd, 2007, 05:11 PM   #3 (permalink)
alsc22ozz
the plugs are no more then 10k miles old
'04 Sentra 1.8
Old Oct 22nd, 2007, 05:22 PM   #4 (permalink)
Z_Tuned_R34
well if its a miss fire it should be your spark plugs, but with all that cranking it might be your starter.
Old Dec 16th, 2007, 10:29 PM   #5 (permalink)
mananitee
check the battery. take it into a shop for a quick check. then check your starter. maybe your distributor and your ignition wires. take out your plugs and re-insert them.
mananitee is offline   Reply With Quote
Old Dec 28th, 2007, 11:00 PM   #6 (permalink)
tabato
My 04 Sentra is doing the same thing. Check info below
Make : NISSAN Model : SENTRA Year : 2004
Manufacturer : NISSAN NORTH AMERICA, INC.
Service Bulletin Num : 05052 Date of Bulletin: SEP 08, 2006
NHTSA Item Number: 10015991
Component: ENGINE AND ENGINE COOLING
Summary:
LONG ENGINE CRANK TIME BEFORE START. *SC
tabato is offline   Reply With Quote
2004 Sentra 1.8 Sentra2004Owner B15 2000-2006 0 Oct 12th, 2007 11:03 PM
Ghosts in the truck - slow starting issues solved again. MrOldLude Truck & SUV 3 Jul 11th, 2007 06:16 PM
Strange but consistent starting problem penguin1944 U13 1993-1997 Altima 1 May 30th, 2007 06:33 AM
starting problem l.v.99ga16 GA16DE 1.6L Engine 4 Sep 29th, 2004 04:35 PM
Changing Instrument cluster from 2004 1.8 to 2004 1.8S Donny2453 B15 2000-2006 9 Sep 18th, 2004 01:05 PM
