Old Jun 20th, 2007, 10:23 AM   #1 (permalink)
willy700
P10171 System too lean bank 1
I am getting a P0171 sestem too lean message when doing a reading on the car. The mechanic could not figure out how to fix.
It runs really rough and hesitates to accelerate when cold and now has started to lose power at higher speeds.
It has also started to shift funny but I think it may be due to the lost power from the engine.
Mechanic has told me to take it to a dealer to figure it out.
Car has 175,000 km on it and is a 2001 GXE.
Does anyone have anysuggestions?
Thanks
willy700 is offline   Reply With Quote
Old Jul 1st, 2007, 02:53 PM   #2 (permalink)
Doja
Id say check your injectors. first thing i would do is use a test light at the injector harness to make sure your getting voltage at the injectors, if all four are getting power, then id take out the rail and injectors to inspect them, or you could check and see if your fuel system has proper pressure. maybe your pump is weak. sorry but at that many miles it could be alot of stuff. good luck
Doja is offline   Reply With Quote
Old Jul 9th, 2007, 10:59 AM   #3 (permalink)
willy700
I took it to the dealer who informed me I needed a new mass air flow sensor.
$600 cdn later the problem is fixed and car runs fine.
Old Jul 10th, 2007, 08:20 PM   #4 (permalink)
Doja
Sorry willy I should have caught that, that was the same exact fault I had a long time ago.
Same problem too. Freakin sensors, too bad theyre not like old cars before the damn emissions crap.
Old Jul 11th, 2007, 02:29 PM   #5 (permalink)
willy700
No kidding, give me my 1985 Aries with carbs. Its likely still getting someone around!.
Old Jul 12th, 2007, 09:39 AM   #6 (permalink)
MS1
I'm having the same problem . I got the same error code .Replaced the MAF sensor. But the car still has no power. and to top it off it won't idel correctly any more. It stalled on me twice this morning. but starts right back up. Anybody hve any ideas?
MS1 is offline   Reply With Quote
Charging System FAQs blackmaxima88 B13 91-94 chassis 4 Nov 8th, 2008 03:53 AM
system to lean lulubear QG18 1.8L Engine 9 Apr 28th, 2006 09:39 PM
97 altima fuel system lean djlnyc U13 1993-1997 Altima 3 Nov 10th, 2005 02:47 PM
Water injection Nizmodore Forced Induction & Nitrous Oxide 0 Jul 2nd, 2004 10:35 AM
