Old Feb 6th, 2007, 03:37 PM   #1 (permalink)
Sentra2704
Sentra2704's Avatar
Send a message via Yahoo to Sentra2704
Service Engine Light Came on
This past Fri I was driving home from work and I looked down and saw that the Service Engine Soon Light came on on my dashboard...I went and got it checked and the P0128 Code came up now my first question is that if this is something I can just fix myself and will it be expensive or should I just leave it to my mechanic to fix it??? and what do I need to get if I can fix it myself....
Nissan....DRIVEN!!!!
There is no SUBSTITUTE for VICTORY!!!- Gen Douglas McArthur
Stay HUMBLE, the HUMBLE man will always come out on top!!! - Santana Moss
Believing is Seeing!! - Sean Stephenson
Sentra2704 is offline   Reply With Quote
Old Feb 10th, 2007, 11:31 AM   #2 (permalink)
Sentra2704
Sentra2704's Avatar
Update I still have my SES (Service Engine Soon) light on but I am really hoping I get this fixed sooner than later...can anyone let me know if it's going to be an expensive repair or is it going to be something relativly cheap...any help would be appreciated
Old Feb 10th, 2007, 11:43 AM   #3 (permalink)
b15chik
Moderator
b15chik's Avatar
Send a message via AIM to b15chik Send a message via Yahoo to b15chik
did you look up what the code meant? it means P0128 - Coolant Temperature Below Required. you might need to replace your thermostat, or you might need to replace your engine coolant temp sensor. i have had to replace mine. try replacing the thermostat first.
b15chik is offline   Reply With Quote
Old Feb 12th, 2007, 09:19 PM   #4 (permalink)
Sentra2704
Sentra2704's Avatar
Thanks....I will but is it easy to fix or is it something that might require me getting under my car I have no idea where the Thermostat is located in my car....any help is greatly appreciated
Old Feb 13th, 2007, 04:29 PM   #5 (permalink)
cral
follow the big hose from the radiator towards your block the thermostat is located at the end on the block side . it will look like a triangle connection at the block with 3 blots holding it into the block. you'll have to remove the hose at the bolts in order to get the thermostat out---make sure when replacing it you put it in the right way ---pay attention to how you remove the old one.
cral is offline   Reply With Quote
Old Feb 14th, 2007, 05:35 PM   #6 (permalink)
Sentra2704
Sentra2704's Avatar
Thanks...when the weather gets warmer I will do it right away..cause it's been snowing and cold here in the Northeast...but thanks for the tip
Old Feb 24th, 2007, 03:35 PM   #7 (permalink)
Team7-B15
yes the thermostat is a fun part to change out, make sure you drain your coolant first or youll get a green surprise with a lot of swearing.
2000 Sentra GXE: K&N drop filter, NGK Platinum IX plugs, ES MMi's, Fidanza SS, MeganRacing FSB, MeganRacing lowering springs, and Spec V shift boot.
Soon to come: Koni Yellow shocks, CAI, X3 header, and ABS front lip with Se-R headlights.
Team7-B15 is offline   Reply With Quote
Charging System FAQs blackmaxima88 B13 91-94 chassis 4 Nov 8th, 2008 03:53 AM
Service Engine Soon Light - For What It's Worth JBW857 Frontier 5 Oct 5th, 2005 05:40 PM
Service Engine Light Fix? felesae Frontier 0 Oct 3rd, 2005 11:54 AM
1997 Pathfinder service engine light prob wolfsdad Truck & SUV 10 Jul 28th, 2005 08:12 AM
98 Frontier Service Engine Light kinger Frontier 2 Feb 13th, 2005 02:28 AM
