Old Feb 6th, 2007, 09:36 AM   #1 (permalink)
lmeissen
Correct spark plugs and Oil?
I suspect my car is running way to hot, but the temp gauge is in the middel.
The temperature outside can be between 34 and 45 degree C in the summer.
I am using NGK BKR6E-11 spark plugs that is a colder plug. for my nissan Almera N16 2001 Hatch. QG18de motor.
I removed the plugs today (only 3000km's with new pistons and plugs), and what a shock... Oil on the plugs. Please take a look at my spark plugs...
http://www.istw.co.za/almera/NewPlug_3000km1.jpg
http://www.istw.co.za/almera/NewPlug_3000km2.jpg
http://www.istw.co.za/almera/NewPlug_3000km3.jpg
http://www.istw.co.za/almera/NewPlug_3000km4.jpg
http://www.istw.co.za/almera/NewPlug_3000km5.jpg
http://www.istw.co.za/almera/NewPlug_3000km6.jpg
What could cause this? Do I have to change my plugs? My service manual and Workshop manual for the same car, use different sparkplugs - or different gap size 0.8
For the full history, folow this threat... http://www.nissanforums.com/general-...hatchback.html
Please, any help will do...
lmeissen is offline   Reply With Quote
Old Feb 6th, 2007, 05:45 PM   #2 (permalink)
cral
your pictures dont show up but oil on the plugs means blown head gasket or piston rings
cral is offline   Reply With Quote
Old Feb 7th, 2007, 04:26 AM   #3 (permalink)
lmeissen
My server is online again. Sorry about that.
I reduced my cap size from 1.1 to 0.8 mm. The car's manual stated 0.8 mm gap size, but autozone and nissan gave me 1.1mm...
Old Feb 11th, 2007, 06:12 PM   #4 (permalink)
cral
doesnt look like all your plugs are covered in ol so my suggestion is trying to get a compression test done on your cilynders looks like an oil ring might have slipped
Old Feb 14th, 2007, 11:56 AM   #5 (permalink)
lmeissen
I've done a compression test, and it is ok. It was timing and wrong tapped cover gasket
Old Feb 24th, 2007, 03:40 PM   #6 (permalink)
Team7-B15
i hate when they have oil or fuel, NGK is the only plug to go with for imports or if you have to denso works ok too.
2000 Sentra GXE: K&N drop filter, NGK Platinum IX plugs, ES MMi's, Fidanza SS, MeganRacing FSB, MeganRacing lowering springs, and Spec V shift boot.
Soon to come: Koni Yellow shocks, CAI, X3 header, and ABS front lip with Se-R headlights.
Team7-B15 is offline   Reply With Quote
engine flush vs Bilstein Engine Flush vs not at all ak47m203 Off Topic 7 Feb 21st, 2008 04:06 PM
Spark plug tunnel oil leak Paul57gt Naturally Aspirated 0 Nov 6th, 2006 01:23 PM
What holds the spark plug tubes to the head? DaDusterDude GA16DE 1.6L Engine 10 Aug 6th, 2006 02:02 PM
96 Pathfinder timing belt and broken spark plugs chris1379 Pathfinder 2 Dec 4th, 2005 10:35 PM
oil in the spark plugs...? Tickwomp Naturally Aspirated 7 Dec 5th, 2003 02:12 AM
