Old Nov 6th, 2006, 10:23 AM   #1 (permalink)
Kevinch
2000 GXE 1.8 problem - please help
Hi folks - I'm a new member today. I joined up to post a question, because I have a problem.
My car is messed up (2000 GXE, 77k miles, 1.8L 5 speed). It's a long story, but the short version is that my SES light was on, & my shop replaced all 4 O2 sensors (P0171) & swapped the #2 & #3 cylinder coil overs (P0303) to fix the problem. The light still came on. I had the codes read by AutoZone, they are the same - even the swap of the coil overs didn't change the P0303. I bought some CRC QD cleaner & some Electrical Contact Cleaner (Radio Shack) & pulled the MAF. It looked clean - but I sprayed it with the Contact Cleaner & re-installed. I then pulled apart every electrical connection that I could find under the hood & cleaned them with the QD. The battery was disconnected for probably 2 hours - because I also replaced the negative terminal lead. The car has a full tank of premium fuel, I added a can of STP Fuel Injection Cleaner.
Started the car & pulled out of my driveway - SES still on (AutoZone did not clear). I believe it is in limp mode - but I didn't know "limp mode" existed. Can't get any RPMs at all. I pulled over & disconnected the MAF to see if that would do anything. It didn't. I limped the car home & looked at the connections - all seemed tight. During that time, I disconnected & re-connected the MAF too. Now, the car won't idle unless the MAF is disconnected. It cranks, starts, then stalls.
I pulled the MAF again. I think I might of originally re-installed it before the contact cleaner dried. I sprayed it with QD & have it sitting in the house.
I don't know what to do, & I 'm looking for some help. Is there anyway to clear my ECU without a reader? Disconnecting the battery for an hour or 2 didn't do it. Should I go longer, or disconnect the ECU? Also - does it sound like I've damaged the MAF? I know if I go the the dealer or a shop, I'll pay through the nose for one. I've seen then on-line for about $125, but I hate to spend that if I don't need to - I just spent over $700 having all the other work done. I'm overdue for state inspection & I have to get it fixed so the SES doesn't come on.
I know I am brand new here - but I am grateful for any advice - please help!
Kevinch is offline   Reply With Quote
Old Nov 6th, 2006, 12:18 PM   #2 (permalink)
Kevinch
Sorry folks - I just realized after checking for responses that I used the term "coil overs" in describing the spark plug coils. Also - I didn't mention in the text or title that it is a Sentra.
Just chalk it up to being worried about what might be wrong with my car.
Old Dec 2nd, 2006, 08:02 PM   #3 (permalink)
chuckie902
wow your having the same shit with your mine keeps giving me a evap error codes and ive replaced all the lines and bypasss valve and solenoid and evap tank so far to, no help resolve
ive got a 2001 gxe 5 speed with the 1.8 litre
and now the clutch or tranny is starting to act up
its only got 100 k km on it
C A N O B D 2 . C O M
cheack you code there
chuckie902 is offline   Reply With Quote
Old Dec 17th, 2006, 09:01 AM   #4 (permalink)
envirocbr
I have the same problem GXE 2001 Auto
Have you replaced the Coil Packs? Just do it!
Evap Canister?
Fuel Pump?
envirocbr is offline   Reply With Quote
2000 Alty Door Lock Problem Mlstrass L30 1998-2001 Altima 0 May 5th, 2006 01:18 PM
2003 Sentra GXE: Brake problem, Idling squeeky ? coolwiz00 B15 2000-2006 2 Jan 26th, 2006 03:45 PM
94 GXE Altima Problem red_sand00 U13 1993-1997 Altima 8 Dec 11th, 2005 01:30 PM
2000 Altima GXE wiper problem Mythos2005 L30 1998-2001 Altima 3 Dec 6th, 2005 09:22 PM
THE GT4 THREAD HATEnFATE Off Topic 353 Apr 7th, 2005 06:43 AM
