Old Apr 13th, 2006, 06:22 PM   #1 (permalink)
kddesai98
ECM replacement + P0171-Sentra GXE '00 (Service engine soon light)
Since couple months I am struggling to correct "Service Engine Soon" problem with my Nissan Sentra GXE 2000. I am located in IL. Since 6 months or so, the SES light was ON. Emission Test requires OBD II clearance, therefore I had to visit the local mechanic to correct the problem. He diagnosed it as P0171 (system too lean bank#1) code. I ended up changing one O2 sensor out of 4, the code still came back after a few miles drive. I ended up changing another O2 sensor for the same pair. Again light came up. Did fuel injection system cleaning too, no luck. I even consulted another mechanic too for 2nd opinion. Now, the mechanic is telling me, i have to change the ECM board (the voltage is significantly low (0.06 or so as I recall) and so scanner shows a lot of fluctuation). So, I am thinking about it and asking for your advice whether that's the real cause & solution? Since couple days, I've noticed lack of power too. I had to heat up the car for 5 min. thenonly, it drives OK. I feel little lack of power with a stop-n-go driving.
Any suggestions? I am little desperate now, the EmissionTest has to be cleared this month, otherwise they may suspend my license.
Will ECM replacement fix the problem permanently?
Thanks very much in advance.
KD
kddesai98 is offline   Reply With Quote
All you ever wanted to know about your Check Engine Light but were afraid to ask JKWright L31 2002 - 2006 162 Jul 14th, 2008 02:44 PM
2002 Sentra GXE Service Engine Soon Light On agentjabba27 QG18 1.8L Engine 19 Jul 17th, 2006 08:18 AM
Service engine light ON plus overheating...need help brother1228 Truck & SUV 8 Apr 2nd, 2005 02:07 AM
Service Engine Soon light Sanguinius QG18 1.8L Engine 8 Mar 29th, 2005 05:19 PM
Service Engine Soon light on! kkspeed Truck & SUV 3 Sep 2nd, 2004 08:27 AM
