in order to get the timing control on the emanage blue to work properly, you need a harness that converts the 4 ignition coils and crank position sensor signal to an rpm signal.
In fact, you need this part to get an accurate rpm signal, period.
part number: 15900904 you will not use 2 of the wires on that.
www.mohdparts.com it's under emanage blue special adapters. That's the exact part number you need!
this will allow you to build better maps because the air fuels will be properly adjusted per rpm.
keep in mind, at wide open throttle in open loop mode, the ECU dumps fuel in, for safety purposes. Top end is where you'll gain the most, but you've got to be really safe. I'd enrich it more, 13.3:1 seems a little on the lean side.
