Which exhaust should i get? and everyone tells me im gonna have to change the stock pipings to 2.5. How can i do that if i have an 02 sensor? and the catalitic convertors? What do you guys suggest.
Please help.
The aem intake is for the SR20...thats the SE for the 2000 model. SE on our cars dont mean nothing. Your best bet would be to get a hotshot intake from hotshot.com. And the stromung exhaust would be a good buy....unless you want to go alittle cheaper for a HKS sports exhaust from performancecenter.com. Or if you want to go even cheaper get a custom one from a muffler shop....but it might show like crap or like a ricer.
Ok, so the AEM is out of the picture. I went to hotshot.com, and their intake says 2001, and it will not fit 04 -05 models. ( i have an 06 ) I also found a CAI called fajita made for my car. Installation wise, would i have to remove the front bumper?? how hard is it.
And the exhaust, should i get 2.5 pipings all around? how would i put the 02 sensor on the new pipings? is it possible?
On this forum you will read about all this stuff from exhaust to cams to clutches. Apply all you read if they make it for your car. I don't know if the 06 different but if they say the intake won't fit then your in for some researching.
2.5" piping is great. Is the 2nd 02 located just below the pre-cat? if so then don't worry about it until you get a header. IF hotshot has a header for you then they will send you a bung to be welded onto your exhaust after the cat-back flange and an extension for your or wire that you will need to cut and sauder or clip.
Ok. My question was... Can i get 2.5 piping all around now for when i get my exhaust? Or is that going to affect any sensors or anything>?
Would they do the 2.5 piping after the last cat? or what
Because the cat-back im looking at is the HKS sport, and that has a 2.5 already, so would that work? www.performancecenter.com, it's under nissan sentra 2001
i remember going to hotshot.com and they saying their intake for qg18's dont fit the 04-05 but it fits mine just fine and i got an 04...i dunno if that helps any but...yeah
