Let me Guess... It either goes Click or URNDT when you hit the switch. with only 15k you should be warrantied..Take it to the DEALER!!! No matter where you take it... Tell them to do both a Voltage AND Amperage test on the Battery, Starter, and Solenoid wires (AKA exciter wire). If they cant tell where the prob is after that then you dont want them working on the car.
The Main starter lead (BIG wire) should have FULL battery voltage and amperage at ALL times (Doesnt matter whether the key is On or Off).
The Solenoid lead should recieve FULL battery power when you place the swithch in the START position. You'll have to consult an FSM or similar for the Amp pull for the solenoid. But you should get a good 15-20amps I would think..
Battery voltage should be 12v MINIMUM! Closer to 13v on a GOOD battery.
Amperage depends on the size battery.
If all this checks out then More than likely either the Solenoid on the starter is goin out...
If not check for..............
The Inhibitor ((Neutral saftey) switch is going out.
The starter Relay or the Ignition Switch has an issue
Hope this is of some help... But Id still check with the Dealer FIRST!
