Old Nov 6th, 2005, 03:37 PM   #1 (permalink)
dsfolk
I hear water running!!
I know this sounds silly, but when I get in my car (usually in the morning) as I am making a turn, I hear water (antifreeze I would imagine) sloshing around in the area behind my dash. There are no signs of leaks inside or outside the car. Is it normal for it to be making this noise? If so, please explain why. I haven't heard this in any of the cars I've ever owned.
dsfolk is offline   Reply With Quote
Old Nov 6th, 2005, 05:52 PM   #2 (permalink)
str8wick3d
Send a message via AIM to str8wick3d
Dosnt sound very normal to me... Take your dash apart and see whats up!
If your gonna mod it. MOD IT TILL IT BLEEDS
str8wick3d is offline   Reply With Quote
Old Nov 8th, 2005, 01:25 PM   #3 (permalink)
dschrier
Nissan Addict
Is your coolant full? Could be an air bubble...sometimes sounds like a "waterfall" when you step on the gas.
dschrier is offline   Reply With Quote
Old Nov 8th, 2005, 02:46 PM   #4 (permalink)
jimb0baby
jimb0baby's Avatar
Send a message via ICQ to jimb0baby Send a message via MSN to jimb0baby
I hear that in my 03 gxe with 35k miles on it too
If you're burning rubber you may be burning oil. Do you smell something burning?
Check out my sentra!
http://www.cardomain.com/memberpage/810538
jimb0baby is offline   Reply With Quote
Old Nov 8th, 2005, 03:17 PM   #5 (permalink)
bigern45
try to bleed the coolant system out. raise the front of the vehicle about two or three feet and let it run with the cap off the radiator.... after a while all of the air should make its way out, then refill it... heater cores are bad about trapping air because of their location and the enter/exit hoses to it...
bigern45 is offline   Reply With Quote
Old Nov 8th, 2005, 10:40 PM   #6 (permalink)
Linc
it does dound like you have an air pocket in your cooling system --
easiest way to get the air bubble out is.... make sure coolant resevior is to max fill line
with car at operating tempature... turn the heater on full heat and fan speed 1.... then put car in first gear { back road } and get your engine RPM up to around 3500 to 4000 RPM-- keep the RPM up for at least 45 seconds in gear.
the air bubble will be forced out the radiator into the coolant resevoir..
hope this works for you... has worked for me many times
Linc is offline   Reply With Quote
water pump installed and one timing chain, now idle surge. 89dragger General Maxima Discussion 4 Oct 6th, 2005 12:40 PM
1989 MAXIMA WON'T START AFTER WATER HOSE FROM WATER PUMP REPLACED reyesstars New Member Forum 2 Sep 17th, 2005 02:17 AM
91' Stanza - Running Really Rough GearS Stanza 1 Aug 9th, 2005 05:44 PM
Water pump replacement Travis GA16DE 1.6L Engine 0 Jul 17th, 2005 06:04 PM
Need help with running quality issues! tripletriple99 L30 1998-2001 Altima 2 Jan 6th, 2004 03:48 PM
