Old Oct 15th, 2005, 03:50 PM   #1 (permalink)
Osprey
Question Oil Filter Part Numbers
Okay, this might take a minute, but here's the background on my question.
I decided that I would start risking my life by crawling under my car to change the oil filter on my 2000 Sentra GXE. I had purchased a filter (NISSAN Part # 15208-65F00) from the dealer many years ago, but always had the dealer change the oil until they recently started charging nearly $35 (in Northern VA) for a simple oil change. Upon looking at the filter that's currently in the car (installed by the dealer during its last oil change), the filter appears to be the same diameter, but about 50% longer. It also has a NISSAN part # of 15208-9E000. At the local WalMart, the recommended FRAM filter (PH6607) looks like the old tiny one I got from the dealer years ago.
MY QUESTION: Which filter should I be using? The larger 15208-9E000 or the smaller 15208-65F00?
Thanks for your help.
sprey
Osprey is offline   Reply With Quote
Old Oct 16th, 2005, 09:40 PM   #2 (permalink)
Louis
sprey
I do not use the original Nissan filter. If you look at purolator cross reference at Pepboys, you will notice the longer one could be used on both Sentra and Quest. I choose the longer one for larger filter surface in the filter.
Louis
Louis is offline   Reply With Quote
Oil filter Part# for 1998 200sx 1.6L ryan7o7 GA16DE 1.6L Engine 3 Aug 13th, 2004 04:17 PM
Must drain oil to put on new oil filter? sweeeems SR-Series Engines (DE/VE) 15 Jul 6th, 2004 07:05 PM
Useful tip for changing oil filter pastorchuck Truck & SUV 3 Jun 20th, 2004 09:38 AM
Recieved Greddy oil filter block for guage senders(info and pics encl.) PatScottAKA99XE GA16DE 1.6L Engine 22 Sep 7th, 2002 07:57 PM
Oil and oil filter question? 1slickser B13 91-94 chassis 18 Jul 10th, 2002 01:22 PM
