Old Aug 3rd, 2005, 05:45 PM   #1 (permalink)
kellybauman
Elusive Noise...NO!
Hi there. If anyone might offer a little guidance, I'd really appreciate it! The car is a 2002 Nissan Sentra GXE w/ approx. 74K miles.
A couple of weeks ago, I notice a slight "clacking" sound, probably closest to the passenger side wheel. So, I took the car to a local mechanic, who diagnosed this as a bad a/c pully bearing (sorry if my terminology is horrible), and replaced it and a couple of belts. ($242, with a $35 battery service)
About 15 minutes after leaving, the sound is present again, at roughly the same level of volume. Pretty much anyone that listens (myself included) thinks it sounds like a loose bearing. So I took it back. The mechanic now says that, with the belts off, there's no noise anymore, and he's suggesting that I replace the water pump, as he noticed a little play ($188). So I guess my questions are these:
Is it silly to keep throwing money at this car? Should I just wait until the problem is very obviously worse, so that it can be more easily diagnosed?
Also, is it good business to charge yesterday's $242, eventhough it didn't fix the problem? Just curious...I don't really know how all that works...
Thanks SO much.
kelly
kellybauman is offline   Reply With Quote
Old Aug 3rd, 2005, 06:24 PM   #2 (permalink)
Kindfiend
absolutely classic
Kindfiend's Avatar
Welcome to the world of getting ripped off by mechanics. It's the reason I started working on my own cars.
Clacking on the passenger side... I think we could use a bit more info. Any particular time it happens, or is it constant? Does it increase with engine speed? I can't think of anything off the bat from the sounds of the problem. Perhaps someone else might be able to shed some light...
Kindfiend
01 Sentra GXE
92 SE-R
Kindfiend is offline   Reply With Quote
Old Aug 3rd, 2005, 07:39 PM   #3 (permalink)
kellybauman
Thanks...
Thanks for the sympathy...
As far as the sound goes, it's pretty contant and really pretty quiet. Quiet enough that the mechanic and I had to stick our heads nearly on the block to hear it. Even then, it's pretty intermittent. But...it's there.
Bascially, it sounds like a ball bearing in a cup, being lightly shaken around, if that makes any sense. It tends to get a bit louder revving the engine.
I'll never know if I was ripped off...they said yesterday's bearing replacement was necessary, and how I can argue? At least they didn't charge today to pull the belts off and reinspect. I guess it's comforting to know that the sound disappeared when the belts were off, maybe? Not likely to be buried in the engine, I guess...but that's me guessing again, which I should know better than to do by now.
Basically, their reccomendation was to wait until the sound is loud/constant enough to diagnose. At this point, arbitrarily replacing things that "could" be faulty is gambling. Who's made of money...I'm certainly not.
Fact is, I probably should have relaxed and waited in the first place.
Again thanks...and that's a great idea working on your own car...I hope I can get that going one of these days!!
Take care,
kelly
And yeah, if anyone's got anything to add, I'd be very grateful!!
Old Aug 6th, 2007, 11:07 AM   #4 (permalink)
almera2000
Did you ever get the problem fixed? I think I've got a similar problem, I'd really appreciate your help. Thanks!
Aleks
almera2000 is offline   Reply With Quote
Brand new Spec V: is this engine noise normal? davejay B15 2000-2006 14 Oct 8th, 2006 10:02 PM
Need help with tire noise on NX jb-nx2k New Member Forum 5 Mar 5th, 2006 08:03 AM
HELP: Strange (dangerous??) noise!! 92PF4X4 Truck & SUV 13 Dec 26th, 2005 09:18 PM
2004 Nissan Altima Steering NOISE AltiNick L31 2002 - 2006 8 Aug 30th, 2005 01:51 PM
For those of you that still have noise problems. LethalAudio Audio 1 Nov 12th, 2003 05:58 AM
