Old Jul 27th, 2005, 04:56 PM   #1 (permalink)
sentra1.8
Stumbling Problem
I have a 2000 Nissan Sentra GXE 1.8L. My car recently started hesitating upon cool startup with an Engine Code P0171. I replaced the Spark plugs and all four O2 sensors (because the service manual suggests a bad O2 sensor in Bank #1 with this code) and had the code erased. However, the stumbling problem still exists and sometimes stalls until it warms up for about a minute or two. I remember getting a code P0420 prior to the P0171 but this went away. Is it possible that the converter is bad? Is there a way to check the converter before sinking more money into the car?
Last edited by sentra1.8 : Jul 27th, 2005 at 05:33 PM. Reason: Wrong code - P0420 not P0142. My bad!
sentra1.8 is offline   Reply With Quote
Old Jul 27th, 2005, 05:08 PM   #2 (permalink)
Kindfiend
absolutely classic
Kindfiend's Avatar
Originally Posted by sentra1.8
I have a 2000 Nissan Sentra GXE 1.8L. My car recently started hesitating upon cool startup with an Engine Code P0171. I replaced the Spark plugs and all four O2 sensors (because the service manual suggests a bad O2 sensor in Bank #1 with this code) and had the code erased. However, the stumbling problem still exists and sometimes stalls until it warms up for about a minute or two. I remember getting a code P0142 prior to the P0171 but this went away. Is it possible that the converter is bad? Is there a way to check the converter before sinking more money into the car?
I had this same problem not too long ago. Chimmike suggested it might be an exhaust gasket before the catalytic converter. Seems like it wouldn't seal correctly until the gasket expanded from the heat.
Edit: I never saw the CEL during this, so our problems may be different, but it's a cheap thing to check. I thought I would throw that out there.
Kindfiend
01 Sentra GXE
92 SE-R
Kindfiend is offline   Reply With Quote
Intermittent (no) starting problem Actionclaw S13 240SX 1989-1994 14 Feb 9th, 2006 08:33 AM
92 240SX: Intermittent Shift Problem 240rocker S13 240SX 1989-1994 7 Jun 8th, 2005 09:59 PM
Sentra vibrations and other problem premk71 B15 2000-2006 8 May 13th, 2005 07:09 AM
Unusual problem solved Zen31ZR Z31 300ZX(T) 2 Feb 19th, 2005 07:45 PM
Hi all, I'm new here. Got a problem with my B14, pls help. Mayonaise B14 95-99 chassis 8 May 12th, 2003 06:03 AM
