which is better Pyroil Engine Flush/or similar products or Bilstein Engine Flush or don't do it all. i heard so much negative feedback with this.
http://www.valvoline.com/pages/produ...asp?product=29
http://www.redwoodgeneral.com/flush.htm
here's one FAQ
http://www.faqfarm.com/Q/Is_a_Gumout...ush_worthwhile
Answer
Sometimes it depends on how many miles there are on your vehicle. It can do some harm by removing too much. An old way I know and do myself is to add one quart of transmission fluid, drive around for an hour or so, then change the oil. It is a softer way to clean the engine instead of those heavy duty engine flushes. Seafoam carb and injection cleaner works great too. I used it in my lawn mower motor and in the gas. Hope I helped!
Answer
Yes.
Answer
No, I do not recommend that anyone put gumout engine flush in their car. It was recommended to me at a professional oil change shop. I pulled out of the parking lot and 15 minutes later my car slung a rod because it had broken oil loose but it didn't all go out with the flush. Instead it clobbered up on other parts and stopped oil from moving through my engine at all. Now I'm having to take this matter to court in order to have my car repaired.
Answer
We had the engine in our 1996 Dodge Caravan (110,000 miles) flushed with Gum Out this summer, and it ruined the engine. We had to purchase a new vehicle. We are negotiating with Speed Lube to pay for the ruined vehicle.
Answer
Never flush an engine -- change your oil faithfully or better yet invest in synthethic oil on your changes and you won't have to think about flushing it. When you "flush" the oil, the slop (especially if your not faithful to oil changes) will go to the oil pan. It then plugs up the oil pump and starves the motor for oil until it cooks it.
Answer
Yes, I think the flush is worth while. MAny "SUV" or truck owners I deal with either neglect or ignore the proper maintenance recommendations on thier vehicle. I have dealt with between oil changes going 4k-10k before they come into my shop. Virtually all the oil has burned or sludged to the point it is caked under the valve cover. For those individuals I say "flush away"!
Answer
The oil pressure on my 90 Ford Aerostar would drop to 0 at idle after the engine was warm. Suspecting the pressure relief valve in the oil pump was stuck, I added a quart of Gumout Engine flush as instructed on the can. Not only is the oil pressure back to normal, the fuel mileage has improved. My guess is the lifters operate more efficiently.
Answer
ok for those who said that gumout can can kill your engin....
I agree it is possible for the sluge to go into your oil pump and cause it plug up, but if you read on the back of the can it says if your vehicle has more than 50,000 miles on it you need to take the oil pan off and clean all the excess sluge off, this will fix your problem with puging up your oil pump, unless it just happend to do it while your flushing your engine in the five min. another thig to stop this is to put a new oil filter on before you begin to flush, because your old filter most likely cant filter enough. Once the flush is done put another oil filter on
Answer
I'd have to say the tranny fluid in the oil is the best idea so far. To prevent the problem I also agree on using synthetic oil. Use store brand synthetic if you're frugal. Basicly, if you need to use gumout, you've been abusing your engine anyway. Had a 4L Jeep and a 5L Chevy k1500 die after gumout clogged the small channels used to distribute the oil - so about 6-8k miles later, the valves were burning up and the engine started braking internal components. And that's with removing the oil pan on both, and changing the sump screen, oil filter, etc.
Answer
You know I have been using the product for years . There are a couple of things to keep in mind . The main one is if this is not a routine thing then it will have to be flushed twice and the filter changed inbetween flushes . What happens is the flush itself doesn't ruin your engine the debre in your engine does . Everyone that has a problem after one flush is due to the engine is so nasty on the inside gunk disolves everything , but it is not drained out the oil pan . You can blame it on the flush or you can blame it on how many times you have missed an oil change at 3500 intervials . If you think changing the oil at every 3500 miles is all there is don't get me started on the air filter , breather filter , pcv valve , and fuel filter !
Answer
I've read everyone's answers and most of them seem to address that unless you have kept up the proper maintenance on your vehicle and that it's the sludge buildup that kills your engine and not the flush, are there any special care instructions written in the directions and if so shouldn't they perform these precautions at the service businesses when the service is being offered? Has anyone contacted a rep at the services corporate offices or Pennzoil-Quaker State company to confirm this? It just seems to me that there's allot of guessing going on as to why a few people have had egine problems after using the product. I personally have used the service after 80,000 miles on my Chevy pickup and have not had a problem since.
Answer
Any "engine flush in a can" has the potential to cause problems. As others have said, the loosened sludge, carbon and particulate will only end up in the sump to cause problems later. (It will also break down the surface tension of the oil.) 10% of the old oil remains in an engine after an oil change. That 10% is in the casting cavities and the bottom of the sump.There is only one safe flush system which, unfortunately, is not available in the USA. Best solution for automobile owners-Buy a cheap oil, run it 500 miles and change the oil and filter. Do that 3 times and then go back to a good quality oil, either mineral or synthetic and use a good quality filter.
Answer
I use kerosene. Drain a quart of old oil out and add 1 quart kero. in. Run at idle 20 mins. then drain. Next, pour 1 quart of oil in the engine with the oil pan plug off so the oil drains. That helps clear out the kero. and loose debris. Then do a reg. oil change, wait 1000 miles and change oil and filter again.
Answer
Hi well just sending an email to find out if i should use an engine flush i've had some people say do and some don't my car runs quite well except for the bit of smoke that comes of the tail pipe dew to burning of oil i've been to 2 different mechenics 1 tells me i need new rings which will cost me around 3 to $400 but the other mechenic tells just change the oil and filter with good oil but flush it first.Anyway the question is should i use the flushing agent on my mitsubishi 95 model
Answer
After carefully doing years of research I have finally come upon a definitive answer to the question of " should I use a sludge solvent?" .
And the answer is:
Maybe
