Go Back   NissanForums.com :: Nissan Forum > Technical > Naturally Aspirated
Naturally Aspirated For you All-Motor lovers
Old Jul 30th, 2002, 09:58 PM   #1 (permalink)
ogip20v
Posts: n/a
engine stall after starting
We have finished installing SR20DE in a project car. When we start the engine after 5 sec the engine stall. Also I notice that the engine have a delay reponse when steping on the pedal. What might cause this problem?
Old Jul 31st, 2002, 11:26 PM   #2 (permalink)
se-r-57
Nissan Fanatic
Send a message via AIM to se-r-57 Send a message via Yahoo to se-r-57
Did you check all the vacume lines? Just a thought.
94 se-r saphire blue with lot's of crap
I'm just a monkey. I don't know shit.
In the white SE-R when the AMG benz did the ricer fly by on 408 :)
se-r-57 is offline   Reply With Quote
Old Aug 1st, 2002, 09:35 AM   #3 (permalink)
ogip20v
Posts: n/a
sr20de problem
Yes! I check it. I'm not sure of the MAF that I installed is correct. Does it effect the engine idling if I install the wrong MAF.
thanks
Old Aug 30th, 2002, 02:35 AM   #4 (permalink)
speedracer1955
Posts: n/a
Have you tried to isolate the MAF???
My daughter had a boyfriend whose 91 Mitsu Eclipse did the same thing...he disconnected(unplugged for testing purposes) the wiring for his MAF and the car ran like a raped ape....his was part of the air cleaner box he also replaced with Cold Air Induction ....
Maybe this helps....???
Their are kits available to bypass the MAF or by a K/N with it already installed...
Old Aug 30th, 2002, 03:31 AM   #5 (permalink)
hpro123
Send a message via ICQ to hpro123
Re: sr20de problem
It affects EVERYTHING.
The MAF is necessary for SR20DEs to figure out how much fuel they should supply at any condition.
Chris
hpro123 is offline   Reply With Quote
Old Aug 30th, 2002, 03:32 AM   #6 (permalink)
hpro123
If he does this on a SR20 the ECU will go in SAFE MODE and it will not rev above 2400rpm.
Chris
Old Aug 30th, 2002, 02:30 PM   #7 (permalink)
ogip20v
Posts: n/a
sr20de MAF
I think i have used the wrong MAF for this engine. Can I use the MAF for SR20DET (Turbo) even thou my engine was naturally aspirated?
Also what sensor should I consider to check if the car produces was smoke when at Idling?
thanks,
Remy
starting engine OmegaManEX GA16DE 1.6L Engine 7 Feb 21st, 2005 02:58 PM
manuel with spec v no1d B15 2000-2006 49 Mar 8th, 2004 04:44 PM
Bad Gas Mileage 1997XETruck Truck & SUV 48 Sep 5th, 2003 02:35 PM
car cranking but engine not starting 94sentrablack B13 91-94 chassis 3 Aug 20th, 2003 10:37 PM
trouble starting engine, engine dies when you give it gas LoOoD GA16DE 1.6L Engine 6 Jun 19th, 2003 05:44 PM
