» Auto Resources
Find Nissan prices on trucks such as a Nissan Xterra, Nissan Frontier and more. Find inexpensive auto leasing rates on a new Nissan such as a Nissan 350Z.
» Sponsor Links
»Garage Storage and Cabinets
Go Back   NissanForums.com :: Nissan Forum > Technical > Naturally Aspirated
Naturally Aspirated For you All-Motor lovers
Old Mar 11th, 2003, 01:52 PM   #1 (permalink)
Murph
Nissan Fanatic
Send a message via ICQ to Murph
fuel efficiency problems
First of all im dealing with a SOHC 4G63, but im not talking anything engine specific here.
Right now im running it in my 92 galant with just less than 200,000KM on it. It has the original O2 sensor so im pretty sure thats the problem. Unfortunatly im told that there are NO MORE O2 SENSORS AVAILABLE Plus when they were available they were $450, and no I cant exactly get one from a junkyard because the car is fairly rare in canada. Its different than the DOHC so im stuck, and the dsmtalk folks havent helped. Im obviously in canada right now but I think the dealerships parts systems are based on north america as a whole.
Also I hear the "rotten egg" smell comes from fuel making its way into the cat? Is this true?
Could an AFC possibly be used to regulate the o2 readings? Would that be a good idea even if it could?
My car is notorious for bad fuel economy but will run on monkey piss with its 8.5:1 compression. Should I run a compression test maybe even if it runs fine?
Im selling it late april but I dont want to be selling a car thats going to run the guy bankrupt through the cost of gas.
Also, thanks again boost_boy for your help awhile ago on the SOHC performance options ps. my replacement car is going to be an s14a so im looking forward to the transition.
Thanks in advance folks!!
http://is2.dal.ca/~mpmurphy/sig.jpg
Drive Safely!
Murph is offline   Reply With Quote
Old Mar 11th, 2003, 04:33 PM   #2 (permalink)
bahearn
bitter old man
bahearn's Avatar
Rotten egg smell is sulfur from gasoline. Nothing you can do about it except replace the cat.
Have you tried a US dealer for that O2 sensor? "No longer available" and "$450" (even Can dollars) sounds like hokum.
Bruce in Houston
bahearn is offline   Reply With Quote
Old Mar 11th, 2003, 07:32 PM   #3 (permalink)
Murph
Nissan Fanatic
No havent tried the U.S. dealer, but I suppose I will find a dealership in washington state.
Replacing the cat will fix the smell?
Drive Safely!
Old Apr 9th, 2003, 03:16 PM   #4 (permalink)
bgriffey
Posts: n/a
Be careful, a "rich" mixture can make for very smelly exhaust fumes. Check to make sure that isn't what's causing the smell before replacing the cat...
Old Apr 13th, 2003, 01:50 AM   #5 (permalink)
dschrier
Nissan Addict
Just a question, but I sometimes get this smell on my 90 sentra, what would cause the fuel to run rich?
dschrier is offline   Reply With Quote
Old Apr 18th, 2003, 03:16 PM   #6 (permalink)
bgriffey
Posts: n/a
Air filter Dirty
O2 sensor
Coolant Temperature Sensor
Old Apr 22nd, 2003, 06:13 PM   #7 (permalink)
anthony jackson
Nissan Fanatic
anthony jackson's Avatar
Send a message via AIM to anthony jackson
i changed my 02 sensor, and my fuel filter. also i replaced my air filter with an intake, and tuned my clutch cable. and i went from 220 miles per tank, to likt 320 miles. and then my fifth gear went out, but i can do 65mph in fourth and still get 300 miles per tank!
1993 Nissan Sentra SE-R
1989 Nissan 240sx
1987 Honda CiviC CRX
Power to weight: the replacement for displacement!
Rest in peace Mama. July 7, 2003
anthony jackson is offline   Reply With Quote
