Go Back   NissanForums.com :: Nissan Forum > Technical > Naturally Aspirated
Naturally Aspirated For you All-Motor lovers
Old Apr 18th, 2007, 05:42 PM   #1 (permalink)
SirReaL303
B15 internal motor balancing unit (motor vibration)... HELP!!!!
I was getting on it merging into I-25 here in Denver and I was at like 6,000rpm in 3rd gear. When I went to shift it into 4th it didn't go into gear and I got a ton of vibration from the motor all the way up through the stick.
So at first I thought I broke a motor mount. Then I thought I had dropped a nut or a bolt. NOW I've come to the conclusion either something went terribly wrong in my clutch assembly that threw everything off or the balancing unit inside of the motor is trashed.
ANYONE who has ripped apart a b15 and dealt with the unit inside of the motor for balancing it out please message me ASAP. I'm lookin at thousands of dollars of repairation which in the beginning was thought to be something small and easy.
Here is a diagram with what I THINK could be wrong circled. Anyone who reads this please forward it to people you know with souped up b15's. I've heard of people removing these for racing purposes but with the vibration I have I can't see how anyone's motor would function for a prolonged period of time under this kind of stress.
The only other thing I could think of is a crank problem (not likely) or something going wrong with the pressure plate/clutch setup as I stated before. PLEASE HELP!
www.NOCARECORDS.com
SirReaL303 is offline   Reply With Quote
Old May 22nd, 2007, 04:28 PM   #2 (permalink)
brianw
Nissan Addict
Send a message via ICQ to brianw Send a message via AIM to brianw
Can you shift into any gears at all? Does it vibrate at all speeds?
brianw is offline   Reply With Quote
Replacing '05 Frontier single-disk unit with '06 Altima Bose 6 disk? blackwaterstout Audio 4 Feb 27th, 2007 05:10 AM
Looking for a decent aftermarket stereo head unit? FrontierJourney Frontier 0 Dec 10th, 2005 05:26 PM
B15 suspension same as N16??? bluestar B15 2000-2006 7 Apr 17th, 2003 09:39 PM
B15 suspension same as N16 Pulsar??? bluestar Suspension & Brakes 2 Apr 17th, 2003 05:48 AM
Stromung Group Deal Ninety-Nine SE-L Group Buys 142 Mar 3rd, 2003 11:19 PM
