could be crank (bearings) thats the only thing that happens to them engines around these parts.
96 B13 Sentra w/GA16DE
15.8@ 86.04 mph (02')
ACT HD PP w/stock disc| B14 Cams| UR Crank Pulley| 3" Intake w/ JWT POP| S-AFC (gen1)| No EGR| NO A/C| Pacesetter Header| ES Bushings| NX2000 Rear Sway Bar| Short throw shifter| 16psi Rad Cap| 15deg Timing| 2" Exhaust w/ 2.5" Magnaflow Muffler| 60mm KA24E TB| VE30DE (Z31) MAF| Accel Super Coil w/ 8mm wires| Adj FPR| Intrax Springs|
