Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Altima/Stanza > L31 2002 - 2006
Old Jul 16th, 2007, 10:59 PM   #1 (permalink)
keithcdcl
Send a message via AIM to keithcdcl
Washer fluid in the coolant tank?
Hello everyone I have a question Id like to ask here since you guys could probably help me more than anyone else right now.
I just put window washer fluid in the coolant tank , I know Im retarded but there both yellow caps and I just wasn't thinking . Well I have a 2002 Altima and I probably put in about half a liter into it while trying to refill my washer fluid tank, and now my car is making a rumbling sound when in motion (either drive or reverse but not neutral or park). I hope that this isnt from my mistake but I have a feeling that it is, what should I do? fill the coolant tank with water to flush it out or just let the stuff pass through? there was water in there when I put the washer fluid in so it shouldnt be a full strength.
Please help, Id really appreciate it.
Thanks in advance,
Keith
keithcdcl is offline   Reply With Quote
Old Jul 18th, 2007, 07:19 PM   #2 (permalink)
keithcdcl
no one has info on this particular circumstance?
Old Jul 20th, 2007, 02:48 PM   #3 (permalink)
reeg420
If you havent started it yet. Then just suck out the washer fluid with like a turkey baster or something. Since it hasnt been mixed with the coolant because its not under pressure. Im pretty sure that you put in the overflow container I cant think of what my girls engine looks like she drives an 03.
If you started it I would flush everything radiator and block. Because Im not sure what washer fluid would do in there but it probably isnt good in the long run. Short time I dont see a problem. As long as you flush it.
reeg420 is offline   Reply With Quote
Looking for washer fluid motor for 85 Pulsar winstonsmith E/CA-Series & GA16i Engines 0 Jun 24th, 2007 05:03 PM
Front Washer FLuid Problem aushaheed Pathfinder 1 Mar 10th, 2007 10:52 PM
Make Your Own Washer Fluid lshadoff General Discussion 10 Jun 1st, 2004 10:55 AM
Leak from windshield washer fluid box? nismo13666 B14 95-99 chassis 8 Apr 23rd, 2004 07:50 AM
do we have a sensor in the washer fluid resevoir??? dry B14 95-99 chassis 7 Dec 25th, 2003 02:57 PM
