Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Altima/Stanza > L30 1998-2001 Altima
Old Mar 27th, 2005, 09:01 AM   #1 (permalink)
wboo
Fuel door will not release, Altima 01 (HELP)
The fuel door on my Alitma will not open. I have managed a few times to get it open to refuel, but up until recently the problem has gotten worse. It appears the fuel release switch is not catching, and will not release the fuel door. The door will not pop open.
Can anyone tell me how much this kinda of work would cost to fix at the Nissan dealership?
wboo is offline   Reply With Quote
Old Apr 6th, 2005, 07:20 PM   #2 (permalink)
Asleep
Super Mod - ALL the time!
Asleep's Avatar
Send a message via AIM to Asleep Send a message via Yahoo to Asleep
isnt the fuel door on the newer altimas electrically opened? check the wiring going to the door and the switch before you take it to an expensive dealer.
Nissan Moderators needed
contact Sassan @ www.SUPERNISSANS.net
http://www.cardomain.com/id/our rides
Asleep is offline   Reply With Quote
Old Apr 13th, 2005, 11:07 AM   #3 (permalink)
SPEEDO
Nissan Addict
"01" is still a cable....
SPEEDO is offline   Reply With Quote
Old Apr 13th, 2005, 11:51 PM   #4 (permalink)
Asleep
Asleep's Avatar
hmmm, its the trunk then that is electrically operated right?
Old Apr 14th, 2005, 12:16 AM   #5 (permalink)
wboo
Sorry my altima is an 02 and the fuel door is open by cabl, not powered.
Old Apr 15th, 2005, 02:48 PM   #6 (permalink)
Asleep
Asleep's Avatar
already been established... now then you need to inspect the cable that releases the fuel door. either thru the trunk or wherever it may run.
Old Apr 15th, 2005, 05:13 PM   #7 (permalink)
tcratboy321
same problem i had just replaced at nissan dealer for $125..pricey but how else u gonna get gas in the car?
tcratboy321 is offline   Reply With Quote
Old Apr 17th, 2005, 04:06 AM   #8 (permalink)
wboo
I will need to bring the car to the dealership, the switch runs along the floor near the car door., the dealer in my area told me it would cost around 30 dollars. I will see when I get to the dealer, sounds to good to be true.
Old Apr 23rd, 2005, 02:30 PM   #9 (permalink)
tcratboy321
it is, the part is only 30 dollars but it is a biatch to install so i just had them do it...othewise you would have to pull up part of your carpet and everything
Old Apr 24th, 2005, 07:38 AM   #10 (permalink)
wboo
I was told that th fuel door will have to be fixed by the body shop. and it will cost around 125 to fix.
Old Apr 24th, 2005, 09:58 AM   #11 (permalink)
tcratboy321
^^ yup..same price for me
Old Apr 25th, 2005, 02:21 AM   #12 (permalink)
SerDaRat93
Send a message via AIM to SerDaRat93 Send a message via Yahoo to SerDaRat93
Time is money
you know time is money for some but not others... the reason it's about a buck an a quarter is because of the labor.. the newer altima's the panels that you have to remove are simple pop on and pop off. the back seat two bolts that are standard size... buy the cable for thirty take two hours and install it just be sure to follow the path of the one your replacing.. don't give in to the bug guy, do it yourself...
also before you go that far, check in the trunk buy your gas door, check to see most have a sort of tensioner, you just unscrew and shorten and screw it back... or twis a few times and the cable tightens up... simple fixes that are FREE... give it a shot.
SerDaRat93 is offline   Reply With Quote
Old Apr 25th, 2005, 07:02 AM   #13 (permalink)
wboo
The damage was done to the fuel door, the cable was not dislodged. I found the fuel door can be opened by pulling and pushing the fuel door simultaneously. I examed the fuel door closely, it appears someone tried to open the fuel in the process bending a peice of the door, which now it will not open properly.
Old Apr 26th, 2005, 10:12 AM   #14 (permalink)
SerDaRat93
so then someone was trying to steal your gas or something and pried open your fuel door!! or was this an exsisting problem from previous owners that just got worse over time?
2005 Nissan Altima SE-R w/Pic. C1 Bender Houston Nissan Enthusiasts 5 Apr 2nd, 2004 02:40 AM
2005 Altima SE-R tekmode Dallas Nissan Enthusiasts 28 Apr 1st, 2004 11:38 PM
94 altima, Help car wants to start but it wont :( 55 code =Elect Fuel Injection jay25 U13 1993-1997 Altima 1 Jan 3rd, 2004 10:48 AM
93 altima fuel injectors snapon4 U13 1993-1997 Altima 0 Dec 28th, 2003 02:26 PM
New recall on Fuel Pump for 2002-2003 Altima PhilGood L31 2002 - 2006 7 Aug 30th, 2003 09:53 AM
