Pull the door panel. The key lock sends a negative pulse to the OEM alarm module to lock & unlock the doors. There should be two wires coming from the key lock to the alarm brain. Check there to see if you are getting a - pulse when the key is turned. Even though you probably are since it does unlock all doors, it's something to check. I added an aftermarket alarm to my wife's Altima using it's keyless entry option. Did this so she would never forget to lock her doors, plus the remotes have far better range than the OEM ones. Not to mention the alarm is upgradeable (remote start, window control) while the OEM isn't. Just my 2 cents worth.
96 SE-R: SR20VE - bolt ons
97 SE-R: SR20DET 54C - on hold - need $$$
03 Altima SE V6: PR CAI/SS grill/alarm & remote start/100 sf Stinger Roadkill/
19's (need tires)/stereo going in next
