i have a 98 Altima, 62,000kms...
I have already:
-replaced spark plugs and wire set,
- distributor cap & rotor
- as well as the mainfold gaskets...
The car seems to run fine but the check engine light is on, and this is what the ECM codes for self diagnostic read:
3 long, 4 short = engine knock sensor and
7 long, 5 short = no definition in my Haynes manual...
I called my dealer, and he says 80% of the time, its 'cause of a loose fuel cap, and to see if the computer resets itself after 10 starts/stops...
Any suggestions? Is it probably a loose fuel cap?
Thanks for your help!
Shafraaz
