P1440 EVAP System Small Leak - Nissan Forum
post #1 of 2 Old Jun 24th, 2008, 11:50 AM Thread Starter
Unhappy P1440 EVAP System Small Leak
All-
(98 Altima)
I read what people experienced when this MIL popped up.
Tried the following:
1) Replace gas cap, nothing
2) Checked two solenoid valves near charcoal canister, they're perfect
3) Inspected all hoses that I have visible access to related to EVAP sys,
nothing wrong or rotted or broken.
Does anyone know what else to look for ?
How pressure sensitive is this system? How small does the leak have to
be for the PCM to get pissed and throw the 1440 code?
If anyone has more information, please share it with me.
Maybe someone diagnosed the leak with smoke and can share where
they found it, it may be a common point of weakness/failure on these vehicles.
Thanks a lot for reading !! Thanks even more for posting a reply!
rpmaltima is offline
post #2 of 2 Old Jun 24th, 2008, 10:28 PM
Nissan Technician
metro273's Avatar
You need to remove the evap canister, with the vent control valve still attached and look closely where the 10mm bolts hold the valve to the canister. You'll most likely see a few small hairline cracks, near the bolts, either on the valve itself or the canister.
This is a common issue when this code appears...good luck!
metro273 is offline
  Nissan Forum > Altima/Stanza > L30 1998-2001 Altima
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
