Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Altima/Stanza > L30 1998-2001 Altima
Old Mar 10th, 2008, 12:47 PM   #1 (permalink)
chrispofahl
Send a message via AIM to chrispofahl Send a message via MSN to chrispofahl
Engine rattle, lifter or timing chain?
I recently ran my poor altima without oil (unknowingly) and now I have a rattle around 3800+ rpm. I was thinking that it's a bad lifter, but is there any possibility that it's the timing chain guides and how would I know which it is? The rattle is coming from the timing chain end of the cams BUT sounds like it's under the valve cover. Any thoughts?
Thanks
chrispofahl is offline   Reply With Quote
Old Mar 10th, 2008, 01:54 PM   #2 (permalink)
Tim90
Send a message via AIM to Tim90
I'm not really sure but it could be something loose? Does it rattle when you REV your engine when ur in park? Try popping ur hood and reving your engine to see if you hear it raddeling and mess around & trouch stuff.. See if somethings loose..
I'm not to smart but try it.
Tim90 is offline   Reply With Quote
Old Mar 10th, 2008, 01:56 PM   #3 (permalink)
Asleep
Super Mod - ALL the time!
Asleep's Avatar
Send a message via AIM to Asleep Send a message via Yahoo to Asleep
being that your engine is a 98 or newer, there are no upper guides. you may have a tensioner problem however.
first off, check the oil pan for dents - i always suggest this for engine rattles on altima engines.
next, pull the valve cover and visually inspect the chain tensioner for abnormal wear.
a haynes manual will show you what to look for if you dont have an fsm.
lastly, which weight oil are you currently running?
Nissan Moderators needed
contact Sassan @ www.SUPERNISSANS.net
http://www.cardomain.com/id/our rides
Asleep is offline   Reply With Quote
Old Mar 10th, 2008, 08:54 PM   #4 (permalink)
chrispofahl
Yeah, thought of most of that myself. No dents in the oil pan and yay for hayne's. Picked one up already and waiting on spring break.Yes it rattles when it's in park, more when it's cold than warm and it quietens down some after it's sat and warmed up nicely. Thanks!
