Old Nov 25th, 2002, 08:26 AM   #1 (permalink)
jmcc1
Posts: n/a
Unhappy Loss of oil pressure
Has anyone experienced a loss of oil pressure. The light comes on and the upper end of the engine starts knocking. Problem has been diagnosed as possible a bad oil pump. But they are saying they can't be sure. No guarantee. Do you have to pull the engine to get to the pump? For the amount of labor they want to replace the pump it seems the engine may have to be pulled. Any thoughts??
Old Dec 3rd, 2002, 11:15 AM   #2 (permalink)
Slurppie
Yea, I'm a freak..
Slurppie's Avatar
I would think that the oil pump would be down by the oil pan which shouldn't require the engine to be pulled.
My Old Ride
My New Ride
Slurppie is offline   Reply With Quote
Old Dec 3rd, 2002, 11:57 AM   #3 (permalink)
jmcc1
Posts: n/a
Thanks. After research I have found that the oil pump is located on the front of the engine and driven directly off the crankshaft. Starting the chore of replacing it this week. Don't have to pull the engine but everything has to come off the front and bottom to access the pump.
Old Dec 3rd, 2002, 01:46 PM   #4 (permalink)
Slurppie
Yea, I'm a freak..
Slurppie's Avatar
Just a thought but take notes and pics so the info can be used in a FAQ one day.
My Old Ride
My New Ride
Old Dec 28th, 2002, 03:17 AM   #5 (permalink)
TJ200SX
Did replacing your oil pump fix your problem? I'm having the same problem now with my '91 pathfinder SE.
2003 Sentra SER Spec V
1996 200SX SE 5-speed :cool: (GA16DE-T)
1991 Pathfinder SE-V6 :cheers:
TJ200SX is offline   Reply With Quote
Old Jan 14th, 2003, 09:16 AM   #6 (permalink)
nismo1989
nismo1989's Avatar
Send a message via AIM to nismo1989 Send a message via Yahoo to nismo1989
You can get to it from below if you just remove all of the plastic splash guards. You should not have to remove the front bumper. Good luck. You can visit www.maxima.org and do a SEARCH in thier archives in the third generation forum, and there you should find a write-up for the procedure. Good luck.
Geoff's 3rd Gen SE... STOLEN!!! X(
http://images.cardomain.com/member_i...169593_121.jpg
Too many mods to list...
Check out my CarDomain page
nismo1989 is offline   Reply With Quote
