» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Maxima > J30 1989-1994 Chassis
Old Jun 7th, 2005, 11:08 PM   #1 (permalink)
rbalan
1993 maxima starting problem
Hello everybody,
I'm a new member and need a help, One of my friend's Maxima 1993 had a problem of intermittently not starting or cranking. But since yesterday its not starting at all. It seems like an anti theft issue. once I tried to disarm through the door key pads and it started. but now again its not starting no matter how much time we try to disarm it. I would like to know if there is any way by which we can diagnose this problem.
Any help in this matter will be highly appreciated.
Thanks and Regards,
Rbalan
rbalan is offline   Reply With Quote
Old Jun 8th, 2005, 08:15 PM   #2 (permalink)
Alpha Male
Send a message via MSN to Alpha Male
By not starting, do you mean nothing happens when the key turns? If so, try wiggling the auto shifter, or put it in neutral and see if it starts. It might be a bad shifter bushing, but more detail is needed. Good luck.
Originally Posted by rbalan
Hello everybody,
Thanks and Regards,
Rbalan
Alpha Male is offline   Reply With Quote
Old Jun 9th, 2005, 06:53 PM   #3 (permalink)
rbalan
Thanks for the response.
I tried wiggling through the shifter and ignition switch harness but no luck. I tried jumping through the battery to the starter solenoid, it cranks but doesn't start. Does this vehicle have immobiliser by any chance? I would appreciate if somebody could get me the starting system wiring diagram.
Thanks again for the help.
Maxima Clutch fade problem...again ( Long) terrys A34 2004-2008 13 Oct 5th, 2009 09:31 AM
Hard Starting 97 Maxima stbdtack A32 1995-1999 Chassis 13 Sep 19th, 2006 12:44 PM
93 Maxima ECCS Relay Problem sun_123 J30 1989-1994 Chassis 0 Jan 27th, 2005 03:39 PM
starting problem l.v.99ga16 GA16DE 1.6L Engine 4 Sep 29th, 2004 04:35 PM
RE: 04 Maxima Clutch pedal fade problem. terrys General Maxima Discussion 7 Sep 24th, 2004 06:34 PM
