Old Feb 5th, 2005, 04:04 PM   #1 (permalink)
Alan284
Need '89 Maxima gear ratios
A friend has a 1989 Maxima with an automatic transmission with a non-working speedometer. I need the gear ratios for 4th (O.D.) and the final drive ratio so I can calculate the rpm for a given speed so she can use the tach as a temporary speedometer.
When the speedometer quit I replaced the speed sensor and the speedometer immediately started working. I tested the old speed sensor and it put out voltage pulses when I rotated its shaft. So it was probably good. Now the speedometer stopped working again. Any ideas? Bad connection? Anyone had a similar problem?
Thanks for any help.
Alan
Alan284 is offline   Reply With Quote
Old Feb 5th, 2005, 09:26 PM   #2 (permalink)
Matt93SE
Will work for beer
The gauge itself is also prone to go out, but I would suspect you have a bad connection or wire somewhere closer to the speed sensor, since it helped when you replaced it the first time.
There are the ratios from a '94 auto, but I'm sure they're the same in the 89.
1st: 2.785
2nd: 1.545
3rd: 1.000
4th: 0.694
final: 3.642
tire height is roughly 24.5", which comes out to about 850 revolutions per mile on the tire. should be everything you need. good luck fixing the speedo.
My website.
Maxima 89 new battery keeps dying npirzada General Maxima Discussion 1 Dec 1st, 2004 10:34 PM
Difference in CA18 and RB20 Gear Ratios [mez] General Discussion 6 Nov 29th, 2004 07:02 AM
Gear Ratios B11SR20DE Motorsports 1 Apr 26th, 2004 11:15 AM
02 SER 5speed gear ratios Lukesblkser QR25 2.5L Engine 2 Jan 8th, 2004 09:53 PM
gear ratios B13Sentra1992 GA16DE 1.6L Engine 0 Jun 15th, 2003 02:11 PM
