Old Jan 27th, 2005, 02:39 PM   #1 (permalink)
sun_123
93 Maxima ECCS Relay Problem
Hi All,
I still have problem with my 93 maxima gxe.My car was cranking but not starting and i found that my ECCS relay was bad. I replaced with a new eccs relay bought from nissan store , but i still had the same problem.
I checked the voltages at the ECCS relay socket and found that i was getting 12volts across the relay switch plug holes and no voltage across the relay coil plug holes. However i was getting 12Volts at one end of the coil plug hole with reference to the ground. Then when i bypassed the relay switch with a jumper wire and the car started and is running fine.
Is this a common problem? Is it ok to run the car this way?
How do i figure out what the problem actually is.
Help please!!
Thank you
sun_123 is offline   Reply With Quote
04 Maxima transmission / brake problem grumble A34 2004-2008 1 Sep 15th, 2004 10:33 AM
1999 Maxima emissions problem mikew General Maxima Discussion 0 Sep 8th, 2004 02:32 PM
95 Maxima Start Problem sampdoria A32 1995-1999 Chassis 1 Jun 10th, 2004 07:09 PM
Any one experienced with '93 Celicas my friends has a problem Binger Off Topic 0 Nov 17th, 2002 04:25 PM
'93 Pathfinder tranny problem Rayman Truck & SUV 1 Oct 31st, 2002 06:29 AM
