Engine Cont Relay does not work
Hi All
I am new this forum. Want to say hi to all of you.
I have a problem with my 93 maxima V6 SOHC. Car cranks but does not start. I found that there was no sparks on the spark plugs. Checked Battery, Starter, Ignition coil , spark plugs etc everything was good.
Then i noticed that my engine check light does not come ON when i trun on the car (normally it used to come ON for few seconds and the it used to goes OFF). So checked the Engine Cont Fuses and relays and found all the fuses were ok but the Engine Cont Relay was bad, so i replaced it with a new relay (bought from nissan part store). But still my engine checklight did not come ON. I was getting 12V at the Engine Cont relay so i decided to bypass the Engine Contol relay. When I bypassed this relay every thing was fine Engine check light came up for few seconds and then went off. And my car started fine there after. I was wondering what this Engine Cont relay is for and Is it ok to bypass the relay? What's the problem with my car?
Need help please.
Thank you
