Old Jan 18th, 2005, 10:23 AM   #1 (permalink)
captkirk
Question Strange noise
I have a '91 Max. It is making a strange noise coming from the front drivers side. Does it only when the car is moving. Kinda sounds like a speedometer cable. Sort of a alternating wirling sound.
I know sounds are hard to explain, but has anyone ever had something like this? Not even sure if the speedo is cable or electric.
captkirk is offline   Reply With Quote
Old Jan 18th, 2005, 11:38 AM   #2 (permalink)
Matt93SE
Will work for beer
check your brakes and make sure there's nothing stuck in there and that your pads are in good shape. sometimes a small grain of sand can get trapped between the caliper and rotor and it will make weird noises until it wears away or falls off.
also check to make sure you didn't hit anything and that your wheel bearings are in good shape.
My website.
Old Jan 18th, 2005, 12:13 PM   #3 (permalink)
captkirk
Brakes are pretty new and front end is solid. I am thinking its the speedo cable. The speedometer is twitching pretty bad. Assuming '91s have a cable.
Old Jan 25th, 2005, 11:04 PM   #4 (permalink)
Matt93SE
Will work for beer
These cars have an electronic speed sensor, so no speedometer cable.
usually the noises are from the above causes, though there are always other issues as well...
does it only happen when accelerating or when the car is cold?
3rd gen MAximas are prone to exhaust stud breakage and they can cause some pretty freaky noises- usually sounds like ticking, but I've heard them chirp, whistle, rattle, tick, all kinds of stuff..
My website.
Old Jan 26th, 2005, 07:04 AM   #5 (permalink)
captkirk
Found it. You were right. It was the brakes. Its the wife's car, so hardley ever drive it. When I did after I saw your first reply, thats what I found.
Thanks!
Old Jan 26th, 2005, 10:59 AM   #6 (permalink)
Matt93SE
Will work for beer
Good stuff.. glad you fixed it.
HELP: Strange (dangerous??) noise!! 92PF4X4 Truck & SUV 13 Dec 26th, 2005 08:18 PM
strange noise StevenLK SR-Series Engines (DE/VE) 0 Dec 29th, 2004 11:50 PM
Strange Noise koureli GA16DE 1.6L Engine 1 Nov 6th, 2004 09:16 AM
strange noise at 4500 rpm dannyca13 S13 240SX 1989-1994 2 Aug 31st, 2004 08:44 PM
Strange noise idon B13 91-94 chassis 1 Jun 23rd, 2003 07:48 AM
