Old Dec 21st, 2004, 04:51 PM   #1 (permalink)
maximabob
93 Maxima head light problems
Low beams work on both sides, high beam only on the driver side, both bulbs are good fuses are good (switched everything from side to side) getting similar voltage on both sides ... does any one have any idea what the problem might be?
maximabob is offline   Reply With Quote
Old Dec 21st, 2004, 07:22 PM   #2 (permalink)
javlin42
Send a message via AIM to javlin42
it could b a bad headlight
javlin42 is offline   Reply With Quote
Old Dec 21st, 2004, 11:31 PM   #3 (permalink)
Matt93SE
Will work for beer
are you running higher wattage bulbs in it? if so, take them out and throw them away. they burn your wiring harnesses. not immediately- usually takes about 5-6 months- but eventually you cook the harness and end up having to replace it.
usually the damage is the socket itself that plugs into the light. stick with the standard wattage bulbs if you don't want to go through the hassle. look for a burned pin on the headlight socket..
If you're still on standard bulbs, also check the light switch inside the car. it has separate contacts for each side on high and low, plus parking (so five or six contacts total). often they can get dirty and stop working, and you'll have one light go out as a result.
check both of those things and see what you come up with.
My website.
Old Dec 22nd, 2004, 12:28 PM   #4 (permalink)
SPEEDO
Nissan Addict
I'll bet its the headlight switch, my truck did the same thing, if you take it a part and clean the contacts it should work for a little longer,or the switch itself runs about $50 (at least for my truck)
SPEEDO is offline   Reply With Quote
FS '93 Maxima needs trans, $300 VehicleTrader Houston Nissan Enthusiasts 1 May 31st, 2004 12:57 PM
Instrument Panel Light Jesse Bolt General Discussion 0 May 2nd, 2004 07:44 PM
head light bulbs webninja Cosmetic Mods 33 Feb 13th, 2003 10:43 AM
Cylinder Head Problems LittlebittaContact E/CA-Series & GA16i Engines 9 Jan 28th, 2003 11:12 PM
Red Head Light coming on tarzan052566 B11/B12/KN13 82-90 chassis 7 Oct 20th, 2002 09:27 PM
