Old Jul 21st, 2004, 07:41 PM   #1 (permalink)
Uncle Kevin
94 Maxima Engine "Clicking" HELP!!
The clicking sound seems to be from under the valve cover [front] it does it every day,but only when it wants to.It comes and goes.Could it be a lifter noise? It changes with RPM alot louder at idle.I have not checked oil pressure with a mechanacal gauge,yet.It is the dual cam motor,is this a common problem,with this motor? Can anybody possibly HELP???
Uncle Kevin is offline   Reply With Quote
Old Jul 21st, 2004, 08:55 PM   #2 (permalink)
3rdmaxse
most likely Its your vtc. take a screwdriver put the handle against ur ear and the tip on the hump on the valve cover and listen and move to the right little by little to pinpoint where it is coming from. If the noise is loudest at the hump (on theleft side) it is ur VTC and U can ground them out.
There is two VTC solenoids that comes out of the heads left of the intake manifold its a 2" high piece with a wireharness ot the top strip back insulation on of of the solenoids and there is a yellow black which u will have to splice a jumper from that wire to ground.
1992 max blk/5spd
"Race Proven Daily"
3rdmaxse is offline   Reply With Quote
Old Jul 26th, 2004, 02:57 PM   #3 (permalink)
Pat200sx
Resident Raider Fan
Pat200sx's Avatar
Send a message via AIM to Pat200sx
Definitly yout VTC's or Variable Timing Cams, you might want to get them checked out
GA16de
Stromung Cat-Back Exhaust, Injen Short Ram Intake, Lucino grill, Se-r rims, Toyo Proxes tires
Originally Posted by MrEous
Pancake titties...FTL
Pat200sx is offline   Reply With Quote
Old Jan 20th, 2005, 10:10 AM   #4 (permalink)
KLrx7
My 92 SE auto does the same thing. Mine goes away when oil pressure builds. If I brake torque it in drive for 2 seconds and let off it quits but will start again after it ides for awhile. My brothers Q45 did the same thing. He says it is the Hydraulic lifters. He cleaned his out and pumed new oil into them by hand then put them back in and it has been fine since.
KLrx7 is offline   Reply With Quote
Old Jan 20th, 2005, 02:29 PM   #5 (permalink)
GRNMAXDMON
GRNMAXDMON's Avatar
yeah its a common problem with the VE motors just do what 3rdmaxse said. once u ground them they will go away. but if u want to replace they will cost alot new so ur better off grounding them.
GRNMAXDMON is offline   Reply With Quote
95 hardbody engine swap... eyeshyed Truck & SUV 5 Jul 6th, 2004 11:25 PM
2000 Maxima - engine knocking ped A33 2000-2003 Chassis 11 Feb 10th, 2004 04:43 PM
trouble starting engine, engine dies when you give it gas LoOoD GA16DE 1.6L Engine 6 Jun 19th, 2003 05:44 PM
Hurt engine, what do u think is wrong in it? pmftv E/CA-Series & GA16i Engines 5 May 23rd, 2003 12:35 AM
F1 engine plays a tune Mudge Off Topic 7 Dec 18th, 2002 02:33 AM
