» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Maxima > J30 1989-1994 Chassis
Old Feb 8th, 2003, 12:05 AM   #16 (permalink)
Hey, guys, it is really not that tough WITH THE RIGHT TOOLS. The timing belt (dayco) has marks on it. Line up the marks on the cam and crank, then put the belt on and count the # of teeth in between. The water pump is just 6 more bolts behind the t-belt. Yeah, I do have a personal compressor and aluminum scuffy pads I use to clean the surface in about 2 minutes of gasket material, then the reassembly begins. Don't forget a new thermostat and gasket with just a touch of Brittney - er.. I mean, silicone to help seal. clean it all up and reassemble. You will need a crank pulley puller and I think a 21 or 24 mm crank bolt socket. I use air tools so I think I have this job down to like 2 hours on my truck and about 3 on my max. Best tip I have is use the 6,8,10,12,14 mm sockets with swivels and short extensions in 1/4 drive. The first time you do it, it will proably take about 8 hours while you are trying to figure out where all the hidden bolts and stuff are, but it is not that bad. That - or pay one of your friends a couple hundred dollars and have them swap out the water pump, the timing belt, all the exterior belts, and a cooling system flush, that should help.
91 Maxima
94 SE-V6 4x4 truck
92 Vert project Mustang
Fixer of all things broken,
Breaker of all things fixed.
Somewhere along the way they usually end up twice as fast.
Mr.Mike! is offline   Reply With Quote
E16 timing belt advice JWolfe E/CA-Series & GA16i Engines 27 Oct 12th, 2003 05:44 PM
How much for a timing belt change for a 97 pathfinder? svneo Truck & SUV 0 Jul 28th, 2003 11:11 AM
97 pathfinder timing belt replacement difficulty? svneo Truck & SUV 1 Apr 25th, 2003 06:42 PM
Slipped timing belt, now bad motor?? SuperHatch E/CA-Series & GA16i Engines 4 Feb 19th, 2003 11:40 PM
Timing belt Tom F GA16DE 1.6L Engine 3 Oct 20th, 2002 05:32 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
