Old Sep 30th, 2003, 09:03 AM   #1 (permalink)
jimlenfert@hotmail.c
Question power steering problem
1991 maxima se great auto. Hard to steer when slow but Ok whern you hit the gas. Have a pressure relief value to put on the power steering but my mechanic doesn't know the location of the valve. Help. Thanks
jimlenfert@hotmail.c is offline   Reply With Quote
Old Oct 15th, 2003, 09:00 AM   #2 (permalink)
No one out there that knows the location of power steering pressure relief value to 1991 Nisson Maxima SE? Thanks Jim Lenfert
Old Oct 15th, 2003, 12:48 PM   #3 (permalink)
Ruben
Friends of ours...
Ruben's Avatar
Send a message via AIM to Ruben
I'm looking now... sorry for the delay.
Ruben - O.G. Club Mofo Mobster
2003 Chevrolet Corvette Z06
The Z06 / Z06 Replaced 350z / 350z Replaced Spec V / Spec V Replaced 3.5 AltimaSE
Ruben is offline   Reply With Quote
Old Oct 17th, 2003, 12:50 PM   #4 (permalink)
MakoMeat
I think your referring to the flow control valve. It should be in the p/s pump housing behind the high pressure side hose fitting. Remove it and a couple of other fitting and the valve should just drop out.
good luck.
MakoMeat is offline   Reply With Quote
Old Oct 18th, 2003, 10:06 AM   #5 (permalink)
thank you Mako Meat. Jim Lenfert.
