Old Sep 22nd, 2003, 05:38 PM   #1 (permalink)
92se
92 seMax from auto to stick shift
I was wondering if anyone knew if the ecu on the SE model with the 190 hp twin cam v6 was the same for the auto and the standard trans? Has anyone done this change before and what issue might arise due to the change? I know that this is somewhat costly venture but the car is rust free, drives and handles extremely well considering the age and original design.
Thank you
92se
Have 240z and VW GTI 337 modified.
Have had 300zx turbo,7-240z's, 13- 510's, 200sx, sentras and too many others to list
92se is offline   Reply With Quote
Old Oct 15th, 2003, 01:03 PM   #2 (permalink)
Ruben
Friends of ours...
Ruben's Avatar
Send a message via AIM to Ruben
Yes, the potential is that that can be swapped, but there is no difference to be had in performance.
Ruben - O.G. Club Mofo Mobster
2003 Chevrolet Corvette Z06
The Z06 / Z06 Replaced 350z / 350z Replaced Spec V / Spec V Replaced 3.5 AltimaSE
Ruben is offline   Reply With Quote
Old Oct 15th, 2003, 04:40 PM   #3 (permalink)
BlueBOB
The Hair of BOOM!
BlueBOB's Avatar
Send a message via ICQ to BlueBOB Send a message via AIM to BlueBOB Send a message via MSN to BlueBOB Send a message via Yahoo to BlueBOB
I believe the ECU's are the same...
you're more likely to find an answer if you search in the 3rd gen section on maxima.org
I'm just a big bang Baller On a Budget...
Cardomain : Dallas Nissan Enthusiasts : DNE Forums : VQPower.com - DTM
BlueBOB is offline   Reply With Quote
Old Oct 17th, 2003, 07:20 PM   #4 (permalink)
mtcookson
Send a message via AIM to mtcookson Send a message via Yahoo to mtcookson
ecu's are the same. the auto tranny Maximas have a seperate tranny computer that is bolted right above the engine ecu. Some things that might cause a problem are the IACV, if the VE engine has it. I'm a VG guy and if you swap the trannies it's also a good idea to swap the idle air control valve (IACV) because on an auto there is more drag from the tranny and therefore needs more air at idle to keep it idling correctly. You will have to drill some holes in the fire wall for the clutch master cylinder to bolt to and you will also need to get a clutch pedal and mount it. You may also want to get a brake pedal from a manual tranny maxima. There's quite a bit more and BlueBOB is right, you might try searching the org for more info. You will notice an increase in performance, contrary to what Ruben said. Manual trannies have a better gear ratio that auto's and stock vs. stock the manual is much quicker. A good idea would be to find a manual tranny with the limited slip differential. The tranny code is RS5F50V for the limited slip. The open differential tranny has the code RS5F50A. Good luck.
This may help. It's for a 4th gen but will give you a general idea http://www.hlh0501.com/5spdconversion.htm
1991 Nissan 450ZX
1991 Infiniti M30 5-speed
mtcookson is offline   Reply With Quote
