Old May 5th, 2002, 03:54 PM   #1 (permalink)
BORNGEARHEAD
Nissan Addict
Send a message via AIM to BORNGEARHEAD
No spark at coil? Help!!!
My friend has got an 89 Maxima sohc 3.0 that won't start. I checked for spark and there is no spark at the coil. Does anyone know what I need to check next? What can I check that is before the coil? He doesn't have any manuals or anything on the car. He has like 200,000 miles on this thing. Is there a crank sensor on these? He said it was running fine, then came out to start it and nothing. It cranks but no start. T.I.A.
93 NX2000 w/sr20ve
92 NX2000
BORNGEARHEAD is offline   Reply With Quote
Old May 5th, 2002, 05:00 PM   #2 (permalink)
PatScottAKA99XE
ex-Super *********
PatScottAKA99XE's Avatar
Send a message via AIM to PatScottAKA99XE Send a message via Yahoo to PatScottAKA99XE
BORNGEARHEAD,
First check all fuses, then check for power to the coil, if you have no power to coil find out why(broken wire,blown fuse,) After this it can get pretty in depth, Ive seen blown ecu's do this, also no crank signal to the ecu would do this.
Patrick Scott
Yeah, thats a roll cage in there.
I shall call him...Mini-Me
PatScottAKA99XE is offline   Reply With Quote
Old May 5th, 2002, 06:31 PM   #3 (permalink)
BORNGEARHEAD
Nissan Addict
I checked all the fuses. I was wondering if there is a relay that I can check. He doesn't have the cover for the relays, so I can't tell which is which. Where does the ecu get crank signal from? Is there a crank sensor? I know Nissan's use a lot of fusible links. Is there one on this curcuit, do you know? I am going to tech school right now and am going to see if I can take it to school to look at it. We have All Data on the computer at school but I don't know if it will give diagnostic procedure to check ecu. If you have any more info please let me know. Thank you very much for the help.
93 NX2000 w/sr20ve
92 NX2000
Old May 5th, 2002, 09:18 PM   #4 (permalink)
PatScottAKA99XE
ex-Super *********
BORNGEARHEAD,
Take a look through All Data, I will tommorow when I am at work, I'll see if I can help you out. And yes there is a crank sensor, as for location I am not sure, I will make sure to look tommorow.
Patrick Scott
Old May 5th, 2002, 09:31 PM   #5 (permalink)
BORNGEARHEAD
Nissan Addict
Thanks alot. I appreciate it. I will look tomorrow.
93 NX2000 w/sr20ve
92 NX2000
Old Jul 10th, 2002, 11:15 PM   #6 (permalink)
Engloid
Send a message via AIM to Engloid
CAS
Originally posted by PatScottAKA99XE
BORNGEARHEAD,
It's in the distributor.
Usually this problem is either the cas, coil, or the ignitor (power transistor)
Engloid is offline   Reply With Quote
Do I have Bad coil? SuperHatch GA16DE 1.6L Engine 3 Feb 14th, 2003 05:11 PM
NDIS coil on plug shaundrake General Discussion 0 Feb 9th, 2003 04:06 PM
my nx will not spark modsquad B13 91-94 chassis 3 Feb 8th, 2003 09:46 AM
help diagnosing... won't start. no spark? natewood GA16DE 1.6L Engine 3 Jan 12th, 2003 12:11 PM
No spark, need help UnaClocker E/CA-Series & GA16i Engines 9 Nov 30th, 2002 09:27 PM
