Old Jun 3rd, 2003, 09:20 AM   #1 (permalink)
Jiggss73
Posts: n/a
Question Steering Wheel Fluid Leak
I've refilled my steering wheel fluid at least twice within three weeks or less. I can't see a leak from the inside of the engine, but sometimes when I park I can see some of it on the ground when I move the car again (after the car sitting in the parking spot for about an hour or so).
Could it be a hose? or the Steering wheel fluid holder?
If so is this a repair that can be done without a mechanic? Or is there a fluid or solution I can purchase to stop the leak?
Other than the hose and the unit is there another place the steering wheel fluid would leak?
Please help me out anyone.. Thank you.
Old Jun 3rd, 2003, 10:31 AM   #2 (permalink)
bgriffey
Posts: n/a
You need to find the origin of the leak. The possible components are:
Pump
Hoses/Lines
Rack & Pinion Steering Unit
Fluid Reservoir
Cooler (if so equipped)
Old Jun 4th, 2003, 05:17 AM   #3 (permalink)
Jiggss73
Posts: n/a
I will check that today and see where it is leaking from.. From those areas you listed. Do you think it would cost a lot to repair?
