Car problems again! - Nissan Forum
post #1 of 23 Old Nov 22nd, 2012, 01:02 AM Thread Starter
Car problems again!
So i went to get something to eat, as i was leaving i heard like a rattling noise. next thing i know i cant steer very good and the car stops charging. First thought is one of the belts broke off but as i looked all the belts are on but moving slowly there is a rattling noise and the car is not charging, it steers but it is kind of hard. Im guessing one of the pullys broke? I just dont know which one. But it is dark out maybe i can get a better look in the morning.
I might add that the car does start but it is just running off the battery and the ps and alt belt are two different belts.
tmorales509 is offline
post #2 of 23 Old Nov 22nd, 2012, 05:59 AM
NF Mod/Nissan Master Tech
smj999smj's Avatar
I've seen this before, unfortunately, on J30 Maximas and if it is what I've seen before, it ain't good! You're going to have to remove the belts and take a look at the crank pulley. I've seen a couple (years ago) that had the nose of the crankshaft break. The other possibility is the crank key sheared, which usually ruins the key slot on the crank; this often occurs when the crank bolt loosens up. Regardless of the issue, I would recommend not running the engine until you inspect the crank pulley and crank.
smj999smj is offline
post #3 of 23 Old Nov 22nd, 2012, 11:26 AM Thread Starter
I am going to inspect right now. I have been told it could be that key thing that broke off. Crossing my fingers that it is something fixable or worth fixing.
post #4 of 23 Old Nov 22nd, 2012, 11:33 AM Thread Starter
first thing i notice if i turn the ac pump pully by hand is that it will turn pretty easily along with the crang pully and i hear kind of a grinding sound from the crank pully.
post #5 of 23 Old Nov 22nd, 2012, 11:52 AM Thread Starter
Ok so it appears the bolt that holds the crank pulley on came off. It was very loose and i was able to take it out by hand. Was it just the bolt that came off that caused this? The bolt was still on and attached it was just loose. Also i might add i did not drive the car very far at all after this happened, as soon as it happened i pulled in to a gas station, maybe 50 feet at most. I did start it for about a minute just to look under the hood to see where the noise was coming from, after that i pulled it home.
post #6 of 23 Old Nov 22nd, 2012, 12:14 PM Thread Starter
On further inspection. Yes the half moon shaped key did appear to break off. When i took the whole pulley off the key was in pieces...So should i just change that key, torque the pulley back on and cross my fingers? I will wait for replies before i go on further.
post #7 of 23 Old Nov 22nd, 2012, 02:22 PM
chuckster57's Avatar
If the slot in the crankshaft for the key is okay, then yes you can install a new key, put the pulley back on and torque the bolt. The key has to fit real tight, any play at all and you'll probably be dead in the water again. If it all works out, you might want to put medium strength lock tite on the bolt.
Although I don't drive a Nissan, I do work on them.
DD is a 2005 Honda Accord and my Work horse is a 1994 Ford F350,CC,LB,DRW with a 7.3 IDI diesel engine.
chuckster57 is offline
post #8 of 23 Old Nov 22nd, 2012, 03:02 PM Thread Starter
ok thanks, i will get on that in the next day or two and report back. The key slot seems to be ok from the look of it, there is still pieces in there from the old key but i will see when i get the new key.
Also im wondering. It leaks a little bit of oil from what i was told is from the crankshaft seal and or camshaft seal. Since i now have this pulley and the belts off would it be much more work to change that seal or is it still alot of work?
post #9 of 23 Old Nov 22nd, 2012, 05:02 PM
The pulley seal is the front main seal. You can change it while the pulley is off. The seal isn't that hard to change if you have the right tools and time. Take your time and you should be okay.
Sounds like the woodruff key sheared off when the bolt loosened up. IMHO you got lucky, most of the time, the groove in the crank gets tore up.
post #10 of 23 Old Nov 23rd, 2012, 02:42 PM Thread Starter
Would anyone happen to know the dimension of the woodruff key? They have a 5pc assortment at autozone.
3/32 X 1/2"
1/8 X 1/2"
5/32 X 5/8"
1/8 X 3/4"
3/16 X 3/4"
post #11 of 23 Old Nov 23rd, 2012, 09:01 PM
smj999smj's Avatar
I can't tell you the size of the woodruff key, but it is Nissan part #00926-51600 if it's a VG30E engine. Also, if it's a VG30E, the front cam and crank seals require removal of the timing belt, cam and crank sprockets and rear timing belt cover. At that point, it would make sense to replace the timing belt and tensioner and, if there's any age to it, the water pump.
post #12 of 23 Old Nov 23rd, 2012, 10:45 PM
Don't know what I was thinking, your absolutely right.
post #13 of 23 Old Nov 24th, 2012, 03:11 PM Thread Starter
Thanks smj, sounds like alot of work, lol. It only leaks a few drops over night so i will just wait and maybe have a shop do it. I think they wanted to charge me like $200 for labor last time i checked. But anyways on the topic.
Well none of those fit. The two that are closest to it, one of them is the same width and depth but it is a little to long, and the other is the same length and depth but it is a little to thin. I am going to check a couple other places tomorrow but if anything the guy at the local shop says i can just grind the longer one down and it will work? The had a bunch of them at the local hardware store to but none were the exact size. I wonder if a place like home depot would have some. Im going to go check tomorrow.
Half of the old one was still inside the pulley so the exact measurement is a 3/16 x 5/8 i believe. I found one on the fastenal website and we have one of those stores 15 mins from here so maybe they have some there in store.
post #14 of 23 Old Nov 24th, 2012, 03:28 PM
The one that is too tall can be used. Carefully grind or file it down. Make sure to remove the edge that will form if you grind it, but be careful not to take any thickness off.
post #15 of 23 Old Dec 1st, 2012, 03:04 PM Thread Starter
Ok so i got the key today but i am not sure if it is supposed to look like this? To me it seems like the key would just fall out?
  Nissan Forum > Maxima > J30 1989-1994 Chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
