Old Mar 5th, 2008, 08:16 AM   #1 (permalink)
maxente
1992 Maxima brake conversion
The drums on the back have some issues. It's probably the spring that keeps the brake shoes apart. It makes this terrible noise when braking. I think they don't hit the braking surface evenly. After taking it out and inspecting it, it works fine for a while and then again. Is it worth it to get a conversion kit to disc brakes or should I get a new braking assembly for the drum?
Axente
maxente is offline   Reply With Quote
Old Mar 5th, 2008, 08:48 AM   #2 (permalink)
MyGreenMax94
Think before posting
MyGreenMax94's Avatar
To complete a rear disk swap, You will need to find a junkyard SE 3rd gen maxima and remove the entire rear wheel/strut housing assemblies from the car. The disk brake assemblies will not simply transfer over to your drum strut/wheel assembly.
You will also need to remove the entire emergency brake cable assembly from the donor disk brake car, the brake cables from a drum brake system will not mount up to the disk brake calipers.
In summary...lots of work to convert...less work to simply replace the worn parts on your drum system..
MyGreenMax94 is offline   Reply With Quote
Old Mar 5th, 2008, 03:58 PM   #3 (permalink)
internetautomart
it's Purple!!!
internetautomart's Avatar
converting to disc is less work than replacing the rear struts. no gland nut to mess with.
Yes, I sell Replacement parts.
Yes, I have a website
Yes, you can PM/email me for more information.
