Old Mar 2nd, 2008, 07:49 PM   #1 (permalink)
i r teh noobz
Nissan Fanatic
i r teh noobz's Avatar
Brake load sensing valve
I'm having a lot of trouble on my sister's '92 Maxima SE (no ABS). Her rear calipers were stuck and the pistons were rusted, so I replaced them with the pads. After a complete flush and bleed, the master cylinder started showing signs of bypassing, so I replaced it today. I bled out the master and hooked it up and the brake pedal felt fairly stiff, but I bled each wheel three more times just to be sure. The pedal still felt stiff, so I started the car to see where it was - nothing. The pedal still goes almost to the floor. After shutting the car off, the pedal felt a little lower than it was before starting.
Are there any special procedures that I may need to follow when bleeding the brakes on this particular car? Does the load sensing valve I saw in the FSM need bled in some special way?
i r teh noobz is offline   Reply With Quote
Old Mar 3rd, 2008, 04:24 PM   #2 (permalink)
internetautomart
it's Purple!!!
internetautomart's Avatar
you don't have the load sensing valve. Only ABS equipped 92-94 SEs had it.
no special bleeding procedure, just patience.
Yes, I sell Replacement parts.
Yes, I have a website
Yes, you can PM/email me for more information.
